What's the Prius III's top speed limited at?
Discussion in 'Gen 3 Prius Main Forum' started by Mrpcar, Feb 25, 2013.
  1. Mrpcar
    Mrpcar Active Member
    542
    253
    Chino Hills, CA
    A chick in a stupid Civic was tailgating me on the freeway, I guess she is one of them Prius haters. So I showed her what a Prius can do. But now I am curious what's the electronic limiter is set at for top speed?
    WE0H likes this.
  2. fotomoto
    fotomoto Senior Member
    5,629
    3,802
    So. Texas
    IIRC, it's around 115-118 mph. You know you could have "kept your foot in it" and found out for yourself! :)
  3. Mrpcar
    542
    253
    Chino Hills, CA
    Well... I was trying to keep it under 3 digits to stay out of jail. The Prius is too eye catchy for the cops. LOL!
    ralleia likes this.
  4. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    It is about 112-113 mph. It is the max speed of MG2 through the gear reducers.
    Mrpcar likes this.
  5. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    No jury will convict you for speeding in a Prius.
  6. Bob Hahn
    Bob Hahn Wingman08
    386
    118
    Jacksonville, Fl
    Awesome, I'd try it but got popped 6 months ago in a little Florida town called Waldo! come to find out it is like the nations #1 speed trap. So embarrassing because I was in my RAV4. I wasn't speeding and then I was really speeding. Doing 65 missed the 55 change and 3 seconds later I'm in a 45! Man did I get crushed. I knew I'd been had too. Those A-holes
    Mrpcar likes this.
  7. fuzzy1
    10,335
    Al Gore's son got a DUI in a Gen2 Prius at just over 100 mph. I think its limiter is 106. The Gen3 limiter is a bit higher, I thought 112.
  8. JeffHastings
    JeffHastings Member
    223
    79
    Whippany, NJ
    The climate guru's boy speeding while drunk? I love it!
  9. The Dude
    The Dude Member
    197
    32
    Phoenix
    Anyone know for sure? I don't understand where you all are getting these estimates??? Pure guesses?
  10. fuzzy1
    10,335
  11. Tideland Prius
    16,445
    More impressive, the iFCD reads 35-40mpg at 94mph!
    cwerdna, WE0H and Mrpcar like this.
  12. mjones12
    mjones12 Member
    115
    26
    North Carolina
    Does the speedometer actually display more than two digits? Mine looks like there's not enough room for a third.
  13. jdcollins5
    5,131
    1,342
    Wilmington, NC
    It is 112 mph. I have a document taken from a listing of all of the gear ratios through the planetary gear set and the Speed Reduction Unit between the planetary gears and MG2. The max car speed at MG2 max rpm is 112 mph.
    I do not have the document at work but will upload it when I get home tonight.
  14. jdcollins5
    5,131
    1,342
    Wilmington, NC
    duplicate post
  15. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    The actual number will depend on the tyre diameter. This will vary a bit between brands and wear factor. Hence "estimates" must be used.
    Speed is not an accurate indication of "max", RPM is.
  16. BZzap!
    BZzap! Senior Member
    1,607
    878
    A "1" is pretty skinny.
    WE0H, '04Prius and Mrpcar like this.
  17. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    "Your Honor, there is irrefutable proof that I wasn't speeding. I was driving a Prius."
    Chris S, Braddles.au, ralleia and 2 others like this.
  18. jdcollins5
    5,131
    1,342
    Wilmington, NC
    Good point. I tried to edit my post but the edit mode was not working correctly, hence my duplicate post. I was going to add based on OEM tires.
    My calculations use my OEM tires and the revolutions per mile from my tire specs. Any other tire sizes would alter this calculation based on the tire's revolutions per mile spec.
  19. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    194 km per hour? On the Autobahn in a euro Prius
    cwerdna likes this.
  20. fuzzy1
    10,335
    That won't change the indicated top speed.
