what's this piece called?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bmparent, Sep 5, 2014.
  1. bmparent
    bmparent Member
    159
    65
    barre ma
    002.JPG ...it came off while I was under the car poking around, located somewhere between the radiator and the engine block. Both of them are in bad shape due to some front-end damage some years ago. Are they important? Should they be replaced? The one on the passenger side has a cable/wire fastened to it so I'm likely to leave it alone. I'm also planning on replacing the wheel-well liners. I'd like to just rip' 'em off because they're both kind of mangled, but I don't know if it's alright to drive for long with out them. Thoughts?
  2. rjparker
    rjparker Tu Humilde Sirviente
    8,134
    4,821
    Texas Hill Country
    Looks like one of your under engine splash shields. Yes I would put it back on or buy new ones. They protect the engine and wiring from too much water and dirt, plus they add mpg due to less air drag on the car. Some aftermarket versions are pretty cheap but usually they just need the clips.
  3. Air_Boss
    Air_Boss Senior Member
    3,991
    1,091
    New Yawk
    The part you imaged is Toyota p/n 53286-47010, a "Radiator Support - Side Seal Panel"
  4. Mendel Leisk
    38,893
    I'd check prices before pulling them out, if possible, suspect refurb' is preferable to buying new ones wherever possible, they can be pricey.
