What's your best MPG?
Discussion in 'Prius c Fuel Economy' started by prius1driver, May 9, 2012.
  1. prius1driver
    prius1driver New Member
    78
    New York
    Here's mine:
  2. PriusCinBlack
    PriusCinBlack Member
    145
    61
    My best, considering all conditions and distance, was over 72 mpg indicated (probably 1-2 mpg less actual) on a 90 mile trip on the freeway, doing 50-55 mpg, on a warm, sunny Sunday afternoon with the prevailing wind at my back. There was a good amount of hill-age, too- just glided down the back end. No drafting involved other than what naturally occurred.
  3. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    My morning drive to work everyday is just under 10 miles, about 9.5
    I normally get in the 72-77ish range
    But highest for the 9.5 miles is 86 mpg.
    I have a small hill at start, and then mostly flat where I stay in the EV range.
    As for a distance with higher miles, 30miles is the furthest in one trip...
    averaged 63mpg there, and 56 on the way back (same route, but hilly)
  4. dano9258
    dano9258 New Member
    59
    Las Vegas, NV
    Mostly downhill to work --> 78.9mpg
    Mostly uphill to home --> 61.0 mpg
  5. dobdru
    dobdru New Member
    26
    Centreville va
    Tonight's fill up was premature, as I still had 3 blips left or est 171 mi.
    435.0 mi. 62.1 mpg!!! I had to log that as the rain on the east coast here and traffic this week has really knocked me down from where I was about 200 mi back @ 67 mpg. Regardless I could not be more thriller right now as this is MY HIGHEST MPG EVER.... I left the Pump with a large smile after putting in $28.00 of fuel. :)
  6. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    there's an entire sub-forum for the Prius C for fuel economy..:
    Prius c Fuel Economy - PriusChat Forums
    my best mpg... if you're only concerned about that number... is 99.9MPG on the MFD
    then again.. i only traveled like 5 miles.
    if you want to factor in distance.. well.. here's this one trip i made:
    but the better one distance wise would be filling up in San Diego, traveling to Hayward, down to San Jose, and then back up to Hayward... (total 533.8 miles) on a single tank.. and it filled up 8.91 gallons..
    that's 59.9mpg for 100% highway... including driving thru the Grapevine.
    2 people like this.
  7. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    300 miles at 60 MPG means 5 gallons consumed. The trip took over 5 hours. That means Prius c sips less than a gallon of gas per hour!
  8. PriusCinBlack
    145
    61
    Averaging 56 mph- not bad, at that speed!
  9. outhouse
    outhouse Member
    125
    37
    auburn ca
    97.7 for 15 miles
    42 for the trip back up
    the same trip before i held 87 mpg for a month
    level ground 57 is about the best I get at 64mph for a 1oo miler
  10. mnaf
    mnaf Junior Member
    36
    SF Bay Area
    Very nice!!
    What was your average (and max & min) highway speed?
  11. SquallLHeart
    826
    247
    San Jose, CA
    i went down to like 30mph on the uphill climb thru the Grapevine, DWL with the rest of the semi-trucks.. and as fast as 70-75mph on the downhill portion.
    otherwise, i was mostly hanging out around 50-60mph for the majority of the trip.
  12. fjpod
    fjpod Member
    419
    72
    New York
    I've done NYC to DC and got about 62-64 mph each way. My absolute highest was a 20 mile trip in NYC at 70 mpg.
    Since I got the car about two and a half years ago, I have averaged 53 mpg...but this spring, as the weather got warm, I have been averaging 60. I know the warm weather helps, but have not experienced this kind of increase before.
  13. maverickf
    maverickf New Member
    113
    Southern California
    This is my best from work to home.
    Warm climate, elevation from 660ft to 235ft, avg speed ~55-60mph following trailers, pulse and glide when possible, coasting downwind, no traffic.
  14. holden94122
    holden94122 New Member
    24
    San Diego
    I have yet to make the drive from SD to the bay area in my wife's Prius C. But I have had some concerns about going through the grapevine, especially the uphill part, as well as the 152 going into Gilroy/San Jose. So looks like the C will be able to climb those hills, but just at a much lower speed. You mentioned that the majority of your trip, you are going around 50 to 60, how long did it take you to go from SD to the bay area? Usually I'm going 80 between grapevine and 152, and that makes it an 8 hr trip from my house in SD to my parents in SJ. I would imagine if I'm going 50-60 most of the way, it takes 9-10 hrs?
  15. SquallLHeart
    826
    247
    San Jose, CA
    well, the car is very well able to go at higher speeds on the uphill climb, but I only went slower for better mileage. the trip was about 9 hours.. averaging about 55 mph.
  16. crebble
    crebble Member
    176
    47
    Shohola PA
    Here's my best commute so far:
  17. prius1driver
    78
    New York
    I just accomplished my best number today. :)
  18. oldasdust
    oldasdust Member
    356
    47
    illinois
    Last fall, cruise set at 65, tires front 40 rear 38, flat interstate dry pavement and a strong tail wind, 77 mpg over 200 mile trip home and a bid smile on my face ,the wife was even impressed at the Prius.
  19. holden94122
    24
    San Diego
    wow very impressive.
  20. SquallLHeart
    826
    247
    San Jose, CA
    i drive a lot.. lol... i've driven 18 hrs straight before... it's no biggie.. (wait.. ok.. i had to stop to get gas... but that's it..)..
    also.. it was during a cross country trip.. so... 18 hrs... for 3 days.. something like that.. averaged 38 mpg in the car i was driving (2011 Scion tC).. which btw EPA rating is like 31 for highway for the car.
