Wheel Alignment scam?
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Pixelfenix, Jan 6, 2025.
  1. Pixelfenix
    Pixelfenix Junior Member
    Montreal
    2023 Prius Prime
    XSE Premium
    So after reading a bit on these forums I've come to understand that dealers often push these on you when they are not required at all. I've unfortunately been suckered into it and had it done as part as my 1 year maintenance.
    When they do wheel alignment they provide you with a nice graphic showing you what they did and to my untrained eye they made it worse? Can someone who understand these things validate if what they did at least didn't make my car worse?
  2. Trollbait
    12,701
    Did they actually do anything, or just wiggle the rear wheels around while on the lift?
    For many cars, it isn't possible, or vary involved, to adjust the camber. I don't think they made it worse; might even help with heavy cornering traction. Some cars have that much camber from the factory. The inside rear tires will wear faster, even with the before settings. If tires are rotated regularly, that wear may not be noticed.
    Snugging up the rear toe could help efficiency.
  3. scotched
    scotched Member
    74
    102
    Encino, CA
    2023 Prius
    It's harder to make fine adjustments on factory suspension. Also, a dealership is not going to put in the same amount work as an a dedicated alignment shop.
    What they tried to do was get your rear left and rear right settings to match. Too much toe kills your tires. The tradeoff of slightly more negative camber is worth dialing out toe here. They're not going to put in the time to dial out camber on stock suspension.
    On a side note, I didn't realize these cars are pushing -2 degrees of camber stock lol.
