Wheel bearing?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Presentdayc, Jul 10, 2019.
  1. Presentdayc
    Presentdayc New Member
    Toledo
    good afternoon!
    Here’s my symptoms. I believe it to be a front wheel bearing but thought I’d ask the experts.
    - road noise that fluctuates with speed
    - seems to have steady hum, fast “wha wha” and little bit of metallic type sounds
    - starts at roughly 25 mph
    - tires are fair but rotated recently with little change
    - when I turn left, the hum increases
    My friend who has worked on G2 Priuses swears that it’s the transaxle but I have my doubts.
    Thoughts?
    Thank you!
    Bobby
    49,508
    welcome!
    i think you're right. or a cv joint. not sure how to tell the difference.
    how many miles on her? bearings are always the prime suspect. sometimes figuring out which one without a chassis ear is the hard part.
  3. Hackmaniac
    Hackmaniac New Member
    58D76421-618E-4E15-852E-9D0571C8D50E.jpeg CBC23409-9077-4CCE-A4AC-E99FA4EBBBED.jpeg 8BAE3685-BF51-42BD-A53E-E903183704D8.jpeg F00EBCFF-0F7F-4ADF-A7F3-01635A72286A.jpeg 08F130CE-BC93-47B0-BE07-04B666BCF2E7.jpeg 9D230A27-6F5A-4480-929A-3EC783DE8CDB.jpeg I replaced both rear wheel bearings and it fixed the same problem for me. Search you tube for how to diagnose a bad wheel bearing. Then watch some more vids on how to easily do it yourself. I bought two NSK’s off rockauto for about 108 each. Now I need to work on the front ones. Mileage at time of replacement was about 175k. But they have been noisy for over a year.
