Wheel Crack
Discussion in 'Gen 2 Prius Main Forum' started by carlbikes, Nov 11, 2009.
  1. carlbikes
    carlbikes Junior Member
    Gainesville, FLorida
    While rotating the wheels last Saturday I noticed a crack on one of the rims. It is on the inside on the outer edge, nearest the rubber. The crack is about 1/16 inch wide. The car has 66,000 miles. New tires were installed at 50,000 miles with Goodyear Fuel Max. (I don't like em'!) :( The wheels have had no abuse. The car is the base model. I suppose the wheel will have to be replaced. Anyone have a similar problem?:confused:
  2. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Weird, that shouldn't happen. Pix?? Maybe the guys who installed
    the new tires screwed up with the bead machine and damaged your
    rims...
    _H*
  3. Doc Willie
    1,717
    144
    Out there, somewhere
    Yes, pictures please, so we know what to look for.
  4. carlbikes
    I'll post a photo after I get back to Florida next week!
  5. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    If this isn'y just a crack in the paint.... how is it holding air?
  6. hill
    8,916
    Evidently it didn't go all the way through. I had a cracked wheel stud . . . paid for by the extended warranty last year, at about 75 ish thousand miles. Then last week, a solder connection cracked in the main window switch to the rear passenger window. FOUR HUNDRED NINTYFIVE DOLLARS saved ... thank you extended bumper to bumper warranty ... kinda sad that it goes away in less than 10K miles (at 100,000Kmiles)
