Wheel Locks who's using them?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by SubCode, Jun 18, 2018.
  1. SubCode
    SubCode Senior Member
    739
    1,341
    Been through heart attacks preparing my self to DD my Volks...SO I had the Mugens which are for sale since I purchase the McGard...
  2. Tideland Prius
    16,604
    All Canadian-spec Prii have wheel locks starting with the Gen 2.
  3. bighammer
    bighammer Junior Member
    One of our Prii came with a set. I took them off and have them in my toolbox in the garage.
    TGrracie and James Powers like this.
  4. lumpy95
    lumpy95 Member
    421
    75
    Mojave Desert, Cal.
    I have them on mine.
  5. Mendel Leisk
    41,829
    Our 2010 came with wheel locks. I got tired of fussing with them, finally sprung for four extra lug nuts, removed the lock nuts.
    One thing if you ARE using them: maybe affix a label with your phone number to the lock nut socket, just in case it ends up in some mechanic or tire shop employee's pocket at the end of the day.
    TGrracie likes this.
  6. marvingloria2011
    marvingloria2011 Active Member
    109
    162
    Winnipeg, Manitoba, Canada
    I've got a set of McGard's for by 19's and the factory ones for my 17's
  7. marvingloria2011
    109
    162
    Lol, I should have done that. I swapped my suspension from the Tanabe's to the Godspeed coils overs and was trying to get the ride height set. During my test drives I forgot to take the key off of one of the rims. I ended up having to order a new key from McGard. Lucky I had the ride height set up already.
  8. Mendel Leisk
    41,829
    Yeah if some mechanic finds he's kept it, even with the best of intentions, if there's no ID on the socket, what's he going to do?
    marvingloria2011 likes this.
  9. padroo
    padroo Senior Member
    2,763
    2,252
  10. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    bighammer and Mendel Leisk like this.
  11. bighammer
    Lug nuts being so much closer to the axis of rotation, I would think that the differences in weight would not be as critical.
  12. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    I'm pretty sure that I read that the McGard ones are designed to be the same weight as the OEM non-locking wheel nuts.
  13. frodoz737
    frodoz737 Top Wrench
    4,715
    2,514
    33
    "Wheel locks" will not stop anyone who wants your wheel/tire assys. The only one it screws are the owners when the adapter is "miss placed" and you need that assy off...now.
  14. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
  15. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    My 2018 Prime came with wheel locks from the dealer. Since Toyota is doing the service for the first 20K miles, I don't have to rotate tires yet. But, when I do, the wheel locks will come off and be replaced with regular lug nuts. Not a lot of Prius wheel thefts in this area of the world.
  16. El Dobro
    El Dobro A Member
    7,088
    3,270
    I stopped using wheel locks years ago, they just weren't worth the effort.
    Mendel Leisk and jb in NE like this.
  17. NewHybridOwner
    607
    283
    W. Michigan
    What "effort"? I had them on the two cars with "fancy" alloy wheels, and the used Prius came with them. When I've rotated the wheels myself, I haven't found that they take any significant effort, and when I've had the tire shop switch at the change of season, I give them the key, and they've never complained.
  18. El Dobro
    El Dobro A Member
    7,088
    3,270
    https://www.ebay.com/itm/STEELMAN-78537-16-Pc-Locking-Lug-Nut-Master-Set-Wheel-Lock-Key-Removal-[​IMG]Tool-Kit/162254953138?epid=671395680&hash=item25c7261ab2:g:ciMAAOSwbURcpcK4
  19. frodoz737
    4,715
    2,514
    33
    Preinstalled wheel locks are a placedo Dealer add on to jack the sticker price. They secure nothing.
    ...and for the record, that master set is only for the honest. ;)
  20. orenji
    orenji Senior Member
    5,887
    3,488
    There are JDM brands where all lugs are locks. This is the way to go. It will take a thief forever to pop off 5 wheel locks (y)
