Wheel out of round. OEM price outrageous.
Discussion in 'Gen 2 Prius Main Forum' started by George W, Feb 2, 2020.
  1. George W
    George W Senior Member
    911
    514
    San Antonio
    Apparently I bent one of my wheels. Haven't gone to a junk yard yet, but Stealership wanted over $430 for new 16". Sheesh.
  2. Mendel Leisk
    41,144
    Do you have the part number? Is it this: 42611-47070?
    I see a sub $100 offering on EBay, used. Picture looks ok:
    Wheel, Disc, TOYOTA, 42611 47070 824697 | eBay
    Bit of road rash evident in the low-res pics, probably Classic Silver Metallic (1F7) is exact match. It is for 3rd gen silver rims, anyway.
  3. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
  4. Rmay635703
    Rmay635703 Senior Member
    2,661
    1,684
    Somewhere in Wisconsin
    2013 Chevy Volt
    Many rims from many other cars will fit, feeling cheap grab a pair usually $25 a pop
    dubit likes this.
  5. George W
    911
    514
    San Antonio
    Thank you for the reference. I'm not sure of the part number, I just saw a slight wobble at the tire shop. As the 3rd owner of this Touring model, I can only hope that these are stock rims. Drivability doesn't seem affected other than slight increase in road noise.
    I don't want to throw any old 16-inch wheel, I'm concerned about the weight matching that of the stock wheels. One thing I have learned about Gen 2 Prius is that they are very sensitive and little things effect them.
  6. PriusCamper
    PriusCamper Senior Member
    12,553
    5,084
    Pacific Northwest, USA
    The 16" are way less common... When I was tracking these prices on craig's list and elsewhere the 15" were in the $75 range.
  7. Rmay635703
    2,661
    1,684
    2013 Chevy Volt
    As he says little things affect the car and going to stock 15” would improve his fuel economy
  8. Salamander_King
    Salamander_King Senior Member
    11,013
    8,942
    New England
    Yeah, a new OEM wheel is way too expensive. At that price you could buy a set of 4 new budget aftermarket alloy wheels, and sell three other OEM wheels on eBay you will be ahead of the game.;)
  9. Mendel Leisk
    41,144
    Meh, just snap up that used OEM 16" on EBay?
    Salamander_King likes this.
  10. Salamander_King
    11,013
    8,942
    New England
    Yeah, that would be the simplest and maybe cheapest solution. But if I was in OP's situation, I would definitely look into buying 15" wheels (either aftermarket or used OEM), especially if the current tires are due for change anytime soon.
  11. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    George W, since you kindly put your location in your profile there is a Wheels America in Selma where you can get the wheel redone for a reasonable price:
    Wheels America San Antonio
    17349 Bell N Dr # 200
    Selma,Texas 78154
    Phone:(210) 590-0602
    moto g(7) power ?
    George W likes this.
  12. Mendel Leisk
    41,144
    What would they do: put it on some sort of lathe, reshape?
    Here we go:
  13. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    My wife was able to bend 3 of mine so far. One bad 2 not so bad. They bend really easy.
    Btw, easiest and fastest way to check for bent wheel is put the wheel on the back of the car and spin the wheel. You can easily see even the tiniest run out.
    Found replacement rims at the 2 different junkyards.
    Grease the mating surface of the wheel to hub area so it will be easier to take that wheel off in the future. The g2 mag wheels get stuck on the cast iron hubs and are really hard to remove. Very common issue.
    Trick for that is loosen the lug nuts and drop the car on the loose wheel and hopefully they come loose.
  14. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    I've asked the one near me. The answer was "proprietary". From what I've experienced I was happy. Last wheel I had done was a 20" wheel for '13 Porsche Panamera. A replacement wheel would be maybe in the $$$$ range. To replace all the wheels with aftermarket would have been cheaper but then I'd need to change the tires....
    moto g(7) power ?
    edthefox5 and Mendel Leisk like this.
  15. George W
    911
    514
    San Antonio
    not sure if i want the car to sit any lower
  16. George W
    911
    514
    San Antonio
    The eBay link took me to a Seller that doesn't carry alloy wheels for a "16
  17. dolj
    dolj Senior Member
    8,391
    4,271
    Wellington, New Zealand
    It won't because it will have a tire with a 65% profile ratio so the overall diameter will be about the same.
  18. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
  19. Mendel Leisk
    41,144
    Yeah that's the way it always is: regardless of rim size, all the approved rim/tire combos (even the temp spare) are roughly the same outside diameter.
  20. jessiejosco
    jessiejosco Member
    62
    42
    I would look on Kijiji or whatever you have locally. I recently picked up a set of 4 mint 15 inch six spokes with covers and almost new summer tires for 300 dollars. I was happy to ditch the 16 inch rims as the don't ride as well, the tires are more expensive, and they bend if you look at them the wrong way.
    Around here people tend to trade in their cars with the rusty winter steel rims and then resell the alloys, so you can often find some for sale.
