Wheel Overhaul: Hub Bearings, Brakes, Shock Struts & Sway Bars
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Prius_Angie, May 18, 2017.
  1. Prius_Angie
    Prius_Angie Active Member
    245
    229
    Saint Louis
    OK, on a recently purchased 2005 Prius I (245,000 miles) and over the course of several days, I swapped out all four wheel hub and bearing assemblies, all four new brakes (disc-rotor/drums; pads/shoes), and both rear shock struts. All wheel hubs were long overdue as rust-brown dust was identified all over the wheel axle area. In fact, they were so dirty that I decided to take some added time to remove and clean out the brake calipers. Added surprise was to replace the worn-out sway bars as well; its boots and grease were corroded and lost long ago. Sway bars were tricky as they required a simultaneous 14mm crescent and 6mm allen wrench to extract.
    P_20170420_141106.jpg P_20170424_220001.jpg P_20170424_221230.jpg P_20170517_153636.jpg P_20170517_153640.jpg P_20170517_181704.jpg P_20170517_182936.jpg P_20170517_182927.jpg P_20170517_182930.jpg P_20170517_174542.jpg P_20170517_172658.jpg P_20170517_172908.jpg P_20170517_174302.jpg P_20170517_174308.jpg
    REAR WHEELS. I replaced the old shock-struts with new ones; careful as they had a noticeable rubber O-ring that controls contact between the car wheel well and top of the strut-shock. Tough preparation was time dedicated to removing of the interior upholstery, which provided access to the top of the rear shock struts. Next were the rear brake shoe-drums. They had some noticeable uneven wear so I decided to swap them both out. Drums brakes are highly challenging for me, as I accidentally ruptured my rear right brake cylinder boots; brake fluid draining a good amount. I decided to just go ahead and replace both right/left brake cylinder rears as they were probably the dated originals.
    P_20170427_131812.jpg P_20170424_221526.jpg P_20170427_115328.jpg P_20170427_131818.jpg P_20170427_131825.jpg P_20170427_115333.jpg P_20170427_130347.jpg P_20170427_130427.jpg P_20170427_130430.jpg P_20170427_132656.jpg P_20170427_132701.jpg P_20170427_141632.jpg P_20170427_141719.jpg
    FRONT WHEELS. As I removed the front left-right tires, rotors, brake calipers— I hung those calipers with a bungee-cord. I also removed the front ABS lines from the front knuckles with a 10mm socket. With 30mm 12pt socket & lots of penetrating oil, I removed both the [front] CV drive axle nuts. It was a tough part as I had to use a breaker bar and an additional 2ft pipe for extra breaking leverage. Swapped out the disc-rotors and brake pads; one set of pads had some noticeable uneven wear from an uneven piston expansion. I replaced and upgraded my rotors for another with blackened rust-proof sealant. Next was the fun part of fully removing the knuckle. I brass punched out both right-left wheel hub & bearings. The standard hammer plinking wasn’t enough, so I had to quickly promote to small sledge hammer. Upon full removal and deconstruction of both front wheel assemblies, I quickly degreased all front suspension parts in the deep sink: steering knuckle & lower ball joint assembly, disc brake dust cover, wheel bearing dust deflector, brake caliper hardware, etc. I used a good helping of grease upon replacing the wheel hub and bearing assembly. I place grease on the hub and inside the contact area of the knuckle. Additionally, all large bolts were re-inserted with a good ribbon of anti-seize cream. Both strut bolts had a noticeable amount of corrosion that I wire brushed off.
    P_20170517_153636.jpg P_20170517_153640.jpg P_20170517_153631.jpg P_20170517_153710.jpg P_20170517_153717.jpg P_20170501_193509.jpg P_20170501_183008.jpg P_20170501_183012.jpg P_20170501_180337.jpg P_20170501_180356.jpg P_20170517_162040.jpg P_20170517_162004.jpg P_20170517_161945.jpg P_20170517_161955.jpg P_20170517_162000.jpg P_20170517_162902.jpg P_20170517_164106.jpg P_20170517_164126.jpg P_20170517_164130.jpg P_20170517_164142.jpg P_20170517_165525.jpg P_20170517_165537.jpg P_20170517_170154.jpg P_20170517_170828.jpg P_20170517_170838.jpg P_20170517_174909.jpg P_20170517_170135.jpg P_20170517_175140.jpg P_20170517_175049.jpg P_20170517_184448.jpg P_20170517_184457.jpg
    Next project will be a quick front end wheel alignment. ; )
  2. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    Rear wheels: How did you bleed the hydraulics after replacing the cylinders? Do you have Techstream for that? I flushed mine a couple of years ago, and can't remember the tricky parts.
    Front brakes: The pictures of the pads remind me to service the caliper pins soon.
    Axle nuts: Good thing you got yours with only a 2' cheater. One car I had to use 3/4 drive with a 4' cheater, and had to roll the car with the wrench against the floor, to use the car's weight to break it loose (I'm only 150#, scrawny old guy). Another I had to saw the nut off after breaking two cold chisels on it.
    Do you think you could you have beat the hubs okay out if the knuckle stayed on the car?
    Thanks for the photos.
    Prius_Angie likes this.
  3. Prius_Angie
    245
    229
    Saint Louis
    Andrew,
    During the process, I lost probably a 1/2 cup of DOT3, hydraulic brake fluid. I did not use the TechStream, instead I had a friend help me bleed the brakes. I am awaiting an old laptop to freeup next month, in order to start using that TechStream. I cannot wait as i just got the items in the mail a few weeks back. Good to know that we can flush the brakes; i will definitely look into that project down the road.
    My front brakes still has a lot of life left in them; but the rust-dust was everywhere and i already had an inexpensive ceramic brake pad set ready to go in. At least I now know where I am at with my brakes.
    Axle nuts: Yup, that was really in there. Getting it done with penetrating oil, 1/2"drive, and 2' cheater was stressful. I must feel quite fortunate if i averted sawing off nuts and any chisel-work. I agree a 3/4"drive is probably the better tool to use.
    No way in punching that bearing hub out of the knuckle if it stayed on the car. You'd still have to remove from your strike path the CV-axle. Plus I created so much brass punch-reverberation from the small sledge hammer strikes. They were significant strikes and necessary to move the process forward. The regular hammer was barely nudging the bearing hubs out of its knuckle socket.
    Cheers.
  4. andrewclaus
    993
    326
    Golden, CO
    I wasn't sure you could do a traditional bleeding with pedal pressure alone on the rears. As I recall, it worked on the front, but it sounds like you got it to work okay.
    My experience with FE/AL as been an aluminum piece inside a steel housing, not the reverse. Thanks for the heads up. Removing the knuckle doesn't add too much to the job, and it's good to know about that.
  5. valde3
    valde3 Senior Member
    2,002
    748
    Finland
    Pull hammer would probably get the bearing out (in 2 pieces) if it was in as good of a condition as in Prius_Angie’s Prius. But if you live somewhere where they salt the roads you will have to work a lot more to get the bearing out. And you would have hard time with wheel speed sensor ring shield.
    Rear brakes can’t really be bled manually because they are not directly connected to pedal so what did you do?
  6. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    Very impressive! I've replaced a wheel bearing on my old 2005. Not the funniest jobs ever! How does it ride now? It's gotta be great. It's a whole new Prius ;-)
  7. Prius_Angie
    245
    229
    Saint Louis
    It rides NOTABLY a lot better. I had been only getting ~35mpg in city/hwy, but now getting low 40s mpg. I do feel coasting/gliding is more fruitful. Still, i have more to do in order to improve mpg. Most noticeable are the creaks & low speed turn wobbles have all went away, now that i have replaced the 2 front sway bars. Tight U-turns and going over speed bumps are no longer noisy & alarming.
    I must add also that at 245k miles, I bought this Prius off a family that neglected car preventive maintenance for a good amount of time; i was up for the challenge. For example it was burning 1qt oil/500miles. [More to this story in a future post to outline Prius rehab at 250k miles].
    P_20170518_144342.jpg P_20170518_144419.jpg P_20170518_144348.jpg P_20170518_144359.jpg
    Aaron Vitolins likes this.
  8. Prius_Angie
    245
    229
    Saint Louis
    P_20170518_131910.jpg here's a photo of that cheater pipe + 1/2" breaker bar combo to remove that 30mm CV-axle nut
  9. Prius_Angie
    245
    229
    Saint Louis
    Andrew & Valde,
    BLEED VALVE. Like i said, i had a friend help me bleed the rear brakes. Perhaps it did nothing but drip DOT3 on the floor, but I recall it significantly spurt out on my chest a few times on a rear spigot. I recall having my bud both engage and disengage the foot brakes while the engine was on. Then, I didnt give it another thought as the brakes were stiff and high on the pedal. See bleed valve diagram and pic. https://priuschat.com/attachments/07-prius-rear-brake-jpg.22216/
    http://techno-fandom.org/~hobbit/cars/maint100k/271rbblcap.jpg
    BRAKE LIGHTS & ABS ON. Glad we are having this conversation on rear brakes, as you may help me unfurl a hiccup. Of note, since replacement of my rear brake shoes, i have these lingering lights that still persist: brakes and ABS. Bleeding the Prius brakes is different and challenging enough. My braking is still excellent forward and reverse, so re-tackling the issue for another day. I have tried to unplug-replug all the ABS sensors connecting each hub bearing as well as disconnecting the neg terminal on the 12V. It still returns. No buzzer sound nor any brake related DTCs.
    Looks like I may have to relook at these rear brakes....
    #9 Prius_Angie, May 18, 2017
  10. Prius_Angie
    245
    229
    Saint Louis
    SELF ADJUSTING PARKING BRAKE. As well, the parking foot brake returned back to good tension after a few days and about a dozen good forced and harsh reverse braking evolutions. I read a lot on the Prius' parking brake ability to self-readjust via tinkering/nudging it back to good health: forward & backward braking. Good it worked out, but still dealing with those unruly CEL lights: brakes and ABS.
    P_20170427_115328.jpg P_20170427_115322.jpg P_20170427_131825.jpg P_20170427_130430.jpg P_20170427_131825.jpg P_20170427_141632.jpg P_20170427_141719.jpg P_20170427_132701.jpg
  11. andrewclaus
    993
    326
    Golden, CO
    Actually, from what I've learned on this site, the Prius rear drums adjust with parking brake lever use, not backing up.
  12. Prius_Angie
    245
    229
    Saint Louis
    thanks.
  13. Prius_Angie
    245
    229
    Saint Louis
    found some more pictures hidden on my phone...
    P_20170425_155757.jpg P_20170425_155744.jpg P_20170425_204610.jpg P_20170425_204524.jpg P_20170425_160215.jpg P_20170425_155809.jpg P_20170425_171802.jpg P_20170427_115333.jpg P_20170426_122746.jpg P_20170426_132448.jpg P_20170426_132445.jpg P_20170426_122800.jpg P_20170425_170510.jpg P_20170425_170526.jpg P_20170425_170534.jpg P_20170425_170604.jpg P_20170426_135854.jpg P_20170425_154338.jpg P_20170425_172351.jpg P_20170425_172355.jpg
  14. Prius_Angie
    245
    229
    Saint Louis
    Also, Im a big proponent of anytime & any excuse to get in under the car to see what's going on and to clean things out. This knuckle is that good excuse to get into it and clean things out. Infact, that was when i noticed that my friend's 2010 Prius didnt have wheel bearing dust deflectors on either right/left front knuckle; unless that is normal?
  15. Marine Ray
    Marine Ray Senior Member
    1,139
    947
    Sparks, NV
  16. Prius_Angie
    245
    229
    Saint Louis
    Andrew,
    Good point in ref, I also serviced my caliper pins as I opened up all 4puns to still find a good amount of clear grease resident.
  17. Prius_Angie
    245
    229
    Saint Louis
    Yup, I forgot that with the 2nd hub, I promoted tools from a brass punch to steel punch. It went much faster, in fact ~40 strikes with brass vs. ~ 10 strikes with steel punch.
    #17 Prius_Angie, May 20, 2017
  18. Prius_Angie
    245
    229
    Saint Louis
    Andrew & Valde, et all,
    OK follow up +3 months later. Finally got my slower laptop up and running with TECH STREAM. I used that to erase the dash lights: HANDBRAKE WARNING, BRAKE, ABS, CHECK ENGINE. 3:4 items resulted from that fiasco earlier with bleeding rear brakes with FOB in [in car proximity] my pocket.
