Wheel question?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by BSBMPG, Jan 26, 2013.
  1. BSBMPG
    BSBMPG Junior Member
    24
    Orange County
    Can I put my 2010 OEM 15" wheels and tires on my 2005 Prius? I currently have 17' scion wheels on my 05' and I am changing the wheels on my 2010, So I was thinking to swap back to stock.
    The 2005 original tires are on 185/65/15 & the 2010 are 195/65/15
  2. 1ULV2H8
    1ULV2H8 Member
    66
    25
    Columbia, SC
    To my knowledge, they should swap just fine.
  3. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    I believe the wheels/rims will fit Ok, but you're speedometer will be off.
    Google tire size calculator, and plug in the two values. The calculator will show you how much difference between the tires and speedometer error.
  4. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    The extra tire size will cause the built in speedo error to reverse direction and may cause the speedo to read slow instead of fast. Your odometer will slow down as well. Otherwise they will work great.
