Wheel size and turning radius?
Discussion in 'Prius c Accessories and Modifications' started by orangenerd, May 13, 2012.
  1. orangenerd
    orangenerd Junior Member
    58
    Lawton
    I am an amateur car guy...I am wondering if the 16" rims will affect my turn radius? I don't want my tires to be rubbing up against my wheel well if I upgrade to 16"s
  2. prius1driver
    prius1driver New Member
    78
    New York
    Good point. I love to know the same.
  3. JimboPalmer
    12,470
    6,866
    Greenwood MS USA
    Here you go
    2012 Toyota Prius C Four Full Test
  4. orangenerd
    58
    Lawton
    I have read that but
    wasn't sure about aftermarket rims and tires
  5. JimboPalmer
    12,470
    6,866
    Greenwood MS USA
    I would assume Toyota bought the best it could, you are free to assume otherwise.
  6. John337
    John337 Junior Member
    Kenmore, WA
    Toyota also increased the offset on their 16" wheel option to about 50mm. The offset is 40mm on the 15x5 wheels. I assume that this was to keep the wider wheels and tires tucked under the fenders. (Note that Toyota's spec for the track on a car with 16" wheels is 2cm less than standard.) They had to change turning radius to accomodate the extra tire width at the inside of the fender. If you use an aftermarket wheel with an offset close to 40mm then your turning radius won't change much assuming your tires don't rub.
