Wheel weight
Discussion in 'Gen 3 Prius Technical Discussion' started by jprates, Jun 27, 2009.
  1. jprates
    jprates https://ecomove.pt
    387
    42
    Moita, Portugal
    2017 Prius PHV
    [FONT=&quot]Would it be possible for one of the lucky new Prius 2010 owners out there
    in the USA to take one wheel out and measure its weight?
    I would be most interested in knowing the weight of both the 15†and the 17â€
    wheels.
    Please, whoever is willing to do this big favor, please also state what tire
    you have on that wheel so that I can try and find the tire weight.
    I am most interested in comparing both rim and tire weights for the new
    Prius.
    The reason is that Toyota has deliberately taken out the possibility of
    having the solar roof with 17†tires because of total weight.
    Toyota also claims that the 15†wheels have a very special and very worked
    out rim which is absurdly light. I want to check that claim.
    It seems that having the solar roof + 17†wheels would result in a much
    higher fuel consumption (presumably equal or even greater than 2nd gen). I’m
    interested in knowing the total weight of the OEM 15†wheels to see if I can
    understand better. I’m betting more on the 215mm wide tire being the main
    reason for the increased consumption.
    Any help is greatly appreciated.[/FONT]
  2. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    From ken@japan and others:
    15X6J: 5X100mm PCD, 45mm offset
    17X7J: 5X100mm PCD, 50mm offset
    17inch:11.0kg
    15inch: 7.4kg
    3 people like this.
  3. jprates
    387
    42
    Moita, Portugal
    2017 Prius PHV
    Thanks David, I had missed that one.
  4. RadioZero
    RadioZero Member
    154
    59
    Orlando
    2018 Prius
    ugh, those 17's are heavy. the 15's are livable. lighter weight wheels for those running 17"s would be nice. if you can find 17" wheels weighing 17-18 lbs each that would be great!
  5. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    There are plenty of inexpensive aluminum wheels that weight in the 15-17lb range. The problem is the tires will still be pretty darn heavy. Most 17" tires seem to be 18lbs at the lightest and 23lbs near the upper end. :(
    My wheels were 15lbs but I understand they are not a style everyone would like. Just posting as an example. :)
  6. David Beale
    5,963
    1,989
    Edmonton Alberta
    Well, if money isn't too much of a concern, I'd wait for Volk Racing to come out with 17" wheels in the Eco series. They look very nice and are very light yet strong. For those who haven't seen them, they were produced originally for the GII Prius, in 15" and 16" size. Cost is close to $3000 for four. I don't have the link handy, but I'm sure someone will chime in with it. You -could- go with the 15" size to minimize weight, remembering that Toyota doesn't change the mechanicals when they change wheel size - they just ensure the overall diameter is very close. ;)
  7. Blizzy_Pri
    Blizzy_Pri New Member
    Pasadena
    I think this is what you're referring to.
    RE30 Eco Drive, which is offered in 17".
    [imglink]http://www.rayswheels.co.jp/emenu/datas2/ECO/020_RE30ECO/logo.jpg[/imglink]
    [imglink]http://www.rayswheels.co.jp/emenu/datas2/ECO/020_RE30ECO/01.jpg[/imglink]
    It's not a Prius, but you get the idea.
    They also have:
    CE28 Eco Drive, ranges from 14" to 16":
    [imglink]http://www.rayswheels.co.jp/emenu/datas2/ECO/010_CE28ECO/logo.jpg[/imglink]
    And we finally have Eco Drive that is only offered in 15":
    [imglink]http://www.rayswheels.co.jp/emenu/datas2/ECO/030_SUPER_ECO/01.jpg[/imglink]
    I wish there was a pic of the RE30 on a Prius. As for the weight, the site, RAYS, doesn't indicate this information.
  8. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    The bad part about all the super lightweight wheels like Ray's is the price. At over $420/wheel you'll have to drive some serious miles to recoup the cost difference compared to a $150 wheel.
    At those costs and assuming a 2mpg difference in MPG it would take approx. 24yrs driving 20,000 miles a year to recover the cost difference between the wheels. :eek:
    $150*4 = $600, 20,000m / 48mpg = 417gallon * $2.70 = $1125/yr in fuel.
    $420*4 = $1680, 20,000 / 50mpg = 400gallon * $2.70 = $1080/yr in fuel.
    $1080 = The difference in price between the wheels
    $1125 - $1080 = $45/yr difference in price paid for fuel
    $1080 / $45 = 24yrs
    But since it's just money. One must go with his/her heart and get a wheel that they think best fits them and you could save upwards of 20galons of fuel a year that won't go contribute to air pollution. :)
  9. jprates
    387
    42
    Moita, Portugal
    2017 Prius PHV
    It's hardly about the price, or about MPG, it's all about looks.
    Yes, we Prius owners can be smug as well LoL as if the world didn't know :D
    In fact I can bet the MPG will fall with these wheels. The OEM 17" and the 15" caps almost cover the wheel area, helping the aerodynamics.
    These pretty wheels are all but aerodynamic. The turbulence on these ones is horrible as hell. I'm not sure the reduced weight is enough to compensate the terrible cd. I think not.
  10. Therand
    Therand New Member
    31
    Atlanta, GA
    How does the Toyota Tire pressure monitoring system work? Do they have little sensors mounted to the inside of the rim?
    I've never tried changing out the rims on a car before. Is there a way to mount the sensors in the new rims so the tire pressure system continues to work?
  11. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Agreed. That is why I only gave them a 2mpg benefit over the cheaper but heavier wheel. :) This also assume you don't go too large in diameter otherwise you put too much weight on the outermost portion of the wheel and it will require more energy to spin the wheel thus lowering mileage further.
    IMO though, they are not worth $3000 for a set. They are not HRE afterall. ;)
  12. Genoz World
    Genoz World ZEN-style living
    797
    22
    La Canada
    OH come on guys, but the 20's on and pump up the psi's to 100! ** :) **
    On a more serious note, the overall weight of the rims DO matter for mpg's and
    even though i switched over to the touring rims and potenza G 09-s, mileage hasn't
    really suffered BUT the handling and overall feel has been 50% increased from the
    stock integrity's.
  13. jprates
    387
    42
    Moita, Portugal
    2017 Prius PHV
    Oh boy... I did not know those HRE ones yet... :eek:
    I'm in Love! Why did you show me this F8L!!!!! :D
  14. David Beale
    5,963
    1,989
    Edmonton Alberta
    The sensors are built into the valve stem. There is a plastic bulge on the inside of the wheel with the electronics in it. They can be moved to the Volk wheels, according to those who purchased them for the GII Prius.
    It's the CE28s that were made for the Prius, and that's the one I'm expecting a 17" to appear. Currently the weights are:
    ce28 ecodrives
    15 inch: 10.1 lbs
    16 inch: 10.8 lbs
    Quite a bit lighter than stock! But of course the tire would have the same weight, and it's out farther from the hub, so would have more effect on mileage. But the lighter wheels would probably handle better on rough roads! ;)
  15. maoira
    maoira Junior Member
    79
    St Paul, MN (formally from San Diego, CA)
    Anyone know the details on the Plus Package wheels? Weight? offset?
  16. WhiteShadow
    WhiteShadow Junior Member
    16
    Folsom, CA
    I know this is an old post, so spare me. I'm posting this info because people continue to use old posts as a source of information.
    I had the chance to weigh one of my 2010 package V wheels (the 17-inch option.) With no tire balancing weights installed, but with TPMS valve stems it weighs 23.4 lbs. on my scale. Certainly not feathery.
    Dylan Doxey and Mendel Leisk like this.
  17. CR94
    CR94 Senior Member
    2,795
    1,227
    Northwestern S.C.
    That's about a whole pound better than specified in post #2.
  18. E46Prius
    E46Prius Active Member
    314
    220
    Costa Mesa
    According to what others have posted:
    Prius stock 15" wheel=16 lbs
    Prius stock 17" wheel=24 lbs
    FRS stock 17" wheel=20 lbs
    Dylan Doxey likes this.
  19. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,459
    92
    The dealer installed some 17x7 MSR (18.2 lbs) wheels on my car before I bought it. Those wheels are what hooked me.
    Together with some aggressive suspension mods, and my driving style, I was getting a long term average of around 43 MPG. Then in September '15, right before 86Fest, I installed my 18" G's (21.5 lbs) wheels. My mileage has been a steady 37 MPG ever since. That was a total of 13.2 lb [ ( 21.5 - 18.2 ) * 4 ] increase in rotating mass.
    Exchanging the Toyo Versado "Eco" tires for Yokohama S-Drive tires probably accounts for some of the MPG decline.
    I am pretty convinced that the increase in rotating mass has a significant impact. The rotating mass is not just a drag on positive acceleration, but also a drag on negative acceleration, decreasing braking efficiency and diminishing benefits from regen-braking.
    To be clear, I am not planning on de-G'sportifying. So, no PM's about buying my wheels please. :cool:
    Anyway, I found my way to this thread because I was curious about OEM wheel weights. I was surprised to see the Personal wheel is heavier than the G's wheel at 23.4 lbs. I'm also a little surprised that the OEM 17" wheel weighs in at as much as 24 lbs. But the OEM 15" at 16 lbs is quite a bit more like what I was expecting to see.
    Anyway, I started googling around and found this page:
    Wheel weight chart most listed MUST SEE!! - evolutionm.net
    Here someone compiled a massive list of wheels complete with weight specs. I refactored the list a little to trim the list down to 18" wheels only, and then sort ascending by weight. Then I double checked, corrected, and supplemented every entry that weighs in at less than 20 lbs. (I was tired.)
    Here's the results.
    14.6 : RS Watanabe Cyclone Forged Mg 18x8 14.6
    14.8 : Buddy Club P1 QF Forged 18x9 14.8
    15.0 : Centerline RPM Forged 18x8.5 15.0
    15.0 : TOM's New Sports II Forged 18x7.5 15.0
    15.5 : SSR Type-C (called Competitions in the US) SSF 18x7.5 15.5
    16.0 : Kosei K1 TS Cast 18x7.5 16.0
    16.1 : Buddy Club P1 QF Forged 18x10 16.1
    16.1 : RS Watanabe Cyclone Forged Mg 18x9 16.1
    16.2 : Mazdaspeed MS-01 Forged Mg 18x8 16.2
    16.3 : Racing Sparco Viper R (Japan Only) Forged/Spun 18x8.5 16.3
    16.3 : SSR Type-C (called Competitions in the US) SSF 18x8 16.3
    16.5 : HRE 504 Forged/Spun 18x7.5 16.5
    16.5 : Stern Aguzze-S07R Forged 18x7.5 16.5
    16.5 : Stern Aguzze-S07R Forged 18x8.5 16.5
    16.6 : Mazdaspeed MS-01 Forged Mg 18x8.5 16.6
    16.7 : Work Emotion Forged 18x7.5 16.7
    16.8 : Kosei K1 TS Cast 18x8 16.8
    16.8 : LimiX Linea BE5-RSK Forged 18x7.5 16.8
    16.8 : Stern Aguzze-S07R Forged 18x9.5 16.8
    16.8 : Volk SE37K Forged 18x9.5 16.8
    16.8 : Wed's TC-005 SSF 18x7.5 16.8
    17.0 : Mazdaspeed Z01 Forged 18x7.5 17.0
    17.0 : SSR Type-C (called Competitions in the US) SSF 18x9 17.0
    17.0 : Volk TE37 Forged 18x7.5 17.0
    17.1 : Nismo LM GT Magnesium Forged Mg 18x10 17.1
    17.2 : Volk TE37 Mag Forged Mg 18x8.5 17.2
    17.4 : Work Emotion Forged 18x8.5 17.4
    17.4 : Work Rezax III Mag Forged Mg 18x8 17.4
    17.6 : Kyoho Tracer Cast 18x7.5 17.6
    17.6 : OZ Superleggera Cast 18x8 17.6
    17.7 : Mazdaspeed MS-01S Forged Mg 18x8 17.7
    17.7 : SSR Type-C (called Competitions in the US) SSF 18x9.5 17.7
    17.7 : Wed's TC-005 SSF 18x8 17.7
    17.8 : BBS RG-R Forged 18x7.5 17.8
    17.8 : SSR GT1 SSF 18x7.5 17.8
    17.9 : BBS RCJ Forged 18x8 17.9
    17.9 : Team Dynamics Visage Forged 18x8 17.9
    17.9 : Wed's TC-005 SSF 18x8.5 17.9
    18.0 : BBS RG-R Forged 18x8 18.0
    18.0 : Enkei Bortex MII (RPM-2) Cast 18x9 18.0
    18.0 : Fikse FM-5 Forged/Spun 18x8.5 18.0
    18.0 : Kyoho Tracer Cast 18x8.5 18.0
    18.0 : Racing Hart CP10 SSF 18x8 18.0
    18.0 : Ro-Ja Formula 5 Forged 18x7 18.0
    18.1 : Nismo LM GT4 Forged 18x8.5 18.1
    18.2 : BBS RK Cast 18x7.5 18.2
    18.2 : Kyoho Tracer Cast 18x9.5 18.2
    18.3 : BBS RG-R Forged 18x8.5 18.3
    18.5 : Kosei K3 Cast 18x7.5 18.5
    18.5 : Kosei RT Penta Cast 18x7.5 18.5
    18.5 : Speedline Routa/GT1 Lite Cast 18x7.5 18.5
    18.5 : Volk GTN Forged/Spun 18x7.5 18.5
    18.6 : Wed's TC-005 SSF 18x9 18.6
    18.7 : BBS RC Cast (soft) 18x8.5 18.7
    18.7 : BBS RCJ Forged 18x9 18.7
    18.9 : BBS RG-R Forged 18x9 18.9
    18.9 : Enkei RPM-2 Cast 18x7.5 18.9
    18.9 : Wed's TC-005 SSF 18x10 18.9
    19.0 : Advan Racing RG Cast 18x9 19.0
    19.0 : Nismo LM GT4 Forged 18x9.5 19.0
    19.0 : OZ Crono EVO Cast 18x8 19.0
    19.0 : Ro-Ja Formula 5 Forged 18x8 19.0
    19.0 : SSR GT1 SSF 18x8 19.0
    19.0 : Volk GTN Forged/Spun 18x8.5 19.0
    19.0 : Work Rezax II Mag Forged Mg 18x8.5 19.0
    19.3 : Enkei NP03 Cast 18x7 19.3
    19.4 : BBS RG-R Forged 18x9.5 19.4
    19.4 : Enkei RPM-2 Cast 18x8 19.4
    19.5 : ADR RS Limited Mase Cast 18x7.5 19.5
    19.5 : BBS RC Cast (soft) 18x10 19.5
    19.5 : BBS RC Cast (soft) 18x8 19.5
    19.5 : Formula F1 (TE-37 style/copy) Cast 18x7 19.5
    19.7 : Racing Hart CP-035R SSF 18x7.5 19.7
    19.7 : SSR GT1 SSF 18x9 19.7
    19.8 : Advan Model 5 Cast 18x8 19.8
    19.8 : Advan Racing TC Cast 18x7.5 19.8
    19.8 : BBS DTM Forged 18x7.5 19.8
    19.8 : BBS RG-R Forged 18x10 19.8
    19.8 : Konig Toxxin Cast 18x7.5 19.8
    20.0 : Enkei RPO-7 Cast 18x7 20.0
    20.0 : Giovanna Akita Cast 18x7.5 20.0
    20.0 : HRE 546 Forged/Spun 18x8.5 20.0
    20.0 : Kosei K3 Cast 18x8.5 20.0
    20.0 : Porsche 996 Cast 18x8 20.0
    20.0 : Ro-Ja Formula 5 Forged 18x9 20.0
    20.0 : SSR Integral SSF 18x8 20.0
    20.0 : SSR Integral SSF 18x9 20.0
    20.2 : Racing Hart CP-035R SSF 18x8.5 20.2
    20.3 : BBS GTII Forged/Spun 18x8 20.3
    20.4 : HRE 445 Forged/Spun 18x10 20.4
    20.4 : Nismo LM GT4 Forged 18x8.5 20.4
    20.5 : 5Zigen Imperio M05 Cast 18x7.5 20.5
    20.5 : Advan Racing RA3-DT Cast 18x10 20.5
    20.5 : Konig Traffik Cast 18x7.5 20.5
    20.5 : Power Racing VS-01 Cast 18x7.5 20.5
    20.5 : Tecnomagnesio MT 5B2 Cast Mg 18x10 20.5
    20.6 : KMC Suicide 320 Cast 18x7 20.6
    20.7 : BBS GTII Forged/Spun 18x8.5 20.7
    20.7 : Enkei RPO-1 Cast 18x8.5 20.7
    20.7 : Nismo LM GT4 Forged 18x9.5 20.7
    20.8 : Enkei RPO-2 Cast 18x7.5 20.8
    20.8 : Fikse FM-10 Forged/Spun 18x8 20.8
    20.8 : Racing Hart Evolution Cast 18x7.5 20.8
    20.9 : Fikse FM-10 Forged/Spun 18x9.5 20.9
    I verified these weights on these sites.
    Rswatanabe Rims Weight
    SSR Rims Weight
    Volk Rims Weight
    How To Spot Fake Volk Wheels
    Buddy Club Rims Weight
    Centerline Rims Weight
    Toms Rims Weight
    Racing Sparco Rims Weight
    HRE Rims Weight
    Stern Rims Weight
    Mazda Rims Weight
    Work Rims Weight
    Weds Rims Weight
    Nismo Rims Weight
    BBS Rims Weight
    Enkei Rims Weight
    Kyoho Rims Weight
    OZ Rims Weight
    Fikse Rims Weight
    Racinghart Rims Weight
    Roja Rims Weight
    Kosei Rims Weight
    Advan Rims Weight
    Adr Rims Weight
    Formulaf1 Rims Weight
    Konig Rims Weight
    It would be nice to supplement this list with pictures. Maybe next time.
    SFO likes this.
  20. James Analytic
    406
    62
    Michigan
    Wondering how the gen 2 Touring 16" rims compare in rim weight?
