wheels stud replacement
Discussion in 'Gen 3 Prius Accessories and Modifications' started by crazyjeys, Sep 3, 2012.
  1. crazyjeys
    crazyjeys Member
    135
    16
    Sunny Socal
    Is it pretty straightforward like the other cars or is there something special For the Prius to replace wheel studs?
  2. Dakine50
    Dakine50 Member
    148
    22
    Nor-Cal
    Nothing different. Sounds like someone is installing wheel spacers (for hellaflush) on the rear hubs?
  3. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Spacers or adapters for a different bolt circle diameter maybe?
  4. crazyjeys
    crazyjeys Member
    135
    16
    Sunny Socal
    That's what I'm planning to do. I'm running 5mm spacers already but I can still go to 8 or 10mms. Im still debating if I should Get the 10 since they offer those with the studs already installed in the spacers but I don't think I want go through the hassle of rolling the fenders in case it goes out too much.
