Wheels...
Discussion in 'Prius c Accessories and Modifications' started by -y0-, Mar 24, 2016.
  1. -y0-
    -y0- Member
    142
    Pacific NW
    So I plan to drop my ride with the Tein Htechs and get some 17s. MB Weapons or Drag DR-38s. Thoughts?
  2. djdawn
    djdawn Active Member
    256
    116
    Escondido, CA
    2014 Prius c
    I like the look of the top one, but I'd lean towards the lighter one. If you're the same type, these might interest you:
    Advanti storm s1
    Storm S1 Matte Black | Advanti Racing
    14.1lbs per wheel for 17x7.
    I'd have gone this direction if I went with 17s.
  3. -y0-
    -y0- Member
    142
    Pacific NW
    Can you post a pic? I like the look of those.
  4. djdawn
    256
    116
    Escondido, CA
    2014 Prius c
    I didn't end up going with the Advantis, so I don't have a pic myself, but one forum user has pictures of his 15in set here on this post:
    Show me your C | PriusChat
    If you're asking for a pic of what I went with, I chose Konig Heliums due to the 60% relative cost over the Advanti Storm S1, and stuck with 15in for ride quality concerns.
    Unfortunately I couldn't find the Konig Heliums in 17in, so it was never really an option. Dominantly I liked the relative price for weight with the Storm S1s when compared to other options. If I was willing to trade a bit of ride quality and get 17s, I'd have gone with the Advantis, hence why I thought I'd bring it up.
  5. Christophers
    Christophers Active Member
    269
    105
    Honolulu
    2015 Prius c
    How wide is that rim?
  6. djdawn
    256
    116
    Escondido, CA
    2014 Prius c
    The rim I went with is 15x6.5, exactly stock.
  7. Christophers
    269
    105
    Honolulu
    2015 Prius c
    I thought the oem width were 15x5 not 15x6.5
  8. djdawn
    256
    116
    Escondido, CA
    2014 Prius c
    I was under the impression that earlier models were 15x5, later ones 15x6.5, and the C4 at 16x??, however I can't find any links or proof so I'm apparently full on wrong. Unfortunately I don't have my steel wheels anymore to check.
    If it's any value, wheel-size.com has the following info for the C
    ◦ Bolt pattern 4x100 ◦ Diameter: 15.0'' - 16.0'';
    ◦ Width (inches): 5 - 6.5;
    ◦ Offset (mm): 39 - 50.
    Toyota Prius c 2014 - Wheel & Tire Sizes, PCD, Offset and Rims specs - Wheel-Size.com
    15x5 is also confirmed on this thread.
    http://priuschat.com/threads/prius-c-steel-wheel-specs.105235/
    Google full on tells you with a search too
    Google
    Sorry for the misinformation.
  9. Christophers
    269
    105
    Honolulu
    2015 Prius c
    I was only asking cause I was thinking about picking up rims but need to know if I should go with a 6.5 width or 7 with a drop.
  10. djdawn
    256
    116
    Escondido, CA
    2014 Prius c
    I'm lowered by ~1in all around, and I'm on 15x6.5 wheels with the oem Assurance tires. I don't think going with a 15x7 is THAT different. The guy with the red C on this post Show me your C | PriusChat has the 15x7 Advantis and didn't mention any issues as well.
  11. Blindhopes
    Blindhopes Junior Member
    Sacramento, California
    I'm also looking into getting new rims. What are your thoughts on 15x7.25 30et. What's the perfect offset? I currently have 15x8 25et. The car rides fine untill its full of passengers then the rear scrapes a bit
    I attached the rim that I'm interested in.
      File size:
      74.9 KB
  12. -y0-
    -y0- Member
    142
    Pacific NW
    So I ended up getting 17x7s and 215/45 tires. Would 205/45 be a better choice?
  13. Mendel Leisk
    41,922
    That's a somewhat bigger od than stock, is it not?
