When did you have to replace the Hybrid Battery?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by auart, Jul 28, 2014.
  1. auart
    auart Junior Member
    74
    Looking for info to see how many folks have had to replace their Hybrid Battery and at what mileage?
    Looking to buy a used prius and curious.
    I had a 2006 Prius but sold it in 2009 and wish I still had it and now need a Prius!
    Bunches of them for sale, but most have over 100,000 miles... should I be too worried?
  2. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    According to Toyota, 2% of each year model that was produced has had the traction battery changed at some point. One year model the figure changed to 3%.
    The traction battery is the least of your worry's. There are items on the Prius that are much more expensive to repair/replace than the big battery.
    If you can pick up a used one with 100K on it, just make sure it has had all the maintenance done on it that is required at 100K. You should be able to get one like that pretty cheap as all the warranty has expired unless you are in a CARB state. I would suggest you raise the bar a little bit, and get yourself a "CPO" Prius. AKA Certified Pre Owned. You can find them at your local Toyota dealer. They will range in various prices, but still should be cheaper than a new one. A CPO comes with a warranty as well as whatever existing warranty from Toyota that is in effect at the time of purchase.
    First Prius we bought was a CPO. Had 45K on the clock. Package #2 2009 Prius. Cost $18K Total with TT&L Came with a 12 month 12K warranty that covered everything. After that the standard warranty was still in effect (Drive Train/Hybrid). Traded in the car earlier this year and bought a new 2013 Model 3. Got a excellent trade in value on the old Prius, financed the new one with 0% interest through Toyota. Put 4K down and my payments are $326 for 36 months.
    EDIT: I apologize for this post. The data above is not 100% correct. Please refer to the consumer reports link shown further down in the string (reference post #6). Also I have posted a link in post #7 that refers to a string where a poll was conducted on this subject here on Prius Chat. (End of Edit)
    Best of luck to you.
    Ron (dorunron)
    #2 dorunron, Jul 28, 2014
  3. fuzzy1
    10,149
    Link please? This sort of distribution, having no age dependence, just doesn't sound right.
    dorunron and cwerdna like this.
  4. taylor_priusII
    taylor_priusII New Member
    17
    Morton, IL
    From what I've read here it's closer to 90% the closer x-axis gets to ten years....
  5. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    From what I've read the world is flat, the moon is made of green cheese, Elvis is alive and elephants can fly. You can read lots of stuff on the internet, but without at least offering a link to the source, nobody is going to believe you. Nothing personal, just how it is.
    Look forward to seeing the links confirming a 90% failure rate.
    nerfer and drysider like this.
  6. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    This is NONE of the unreferenced sources above, it is Consumer Reports, but at least I have a reference! The article is demeaning the Honda Hybrids and just using the Prius as a baseline, but those base line numbers are what I think the OP was wanting.
    Honda Civic Hybrid Battery Reliability | Hybrid Batteries - Consumer Reports News
    If I wanted to inflate these numbers with 'green cheese' I would speculate that these percentages only involved Toyota dealerships and do not include re-manufactured or used batteries, just new Toyota supplied batteries. I have no stats for those used batteries, and I suspect no one else does either, unless Consumer Reports is actually asking the owners in their annual survey. And then I would wonder about the actual wording: "Did you have a Hybrid battery failure?" may well get different percentages than "Did you buy a new Hybrid Battery?"
    Summary: I do not completely trust these numbers but they are the best I have. And way better than numbers with no reference at all.
    #6 JimboPalmer, Jul 28, 2014
  7. dorunron
    3,318
    1,103
    Houston, TX
    I apologize for not providing a link to back up what I posted. Furthermore, the data I posted seems to not be 100% correct. I was under the impression those numbers were fairly accurate. I thought I had read that info here on PC.
    I would refer to the consumer reports info that is posted in this string, and also take a look at the results of a poll that was run here on Prius Chat.
    Hybrid Battery Survey-Gen2 Prius 2004-2009 | Page 6 | PriusChat
    Best of luck to you,
    Ron (dorunron)
  8. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    This is Consumer Reports testing a 10 year old 2001 Prius (the battery packs in the Gen2 Prii are better):
    The 200,000-mile question: How does the Toyota Prius hold up?
    "Our testers were also amazed how much the car drove like the new one we tested 10 years ago."
    I know I've seen references to a very high percentage of original Toyota hybrid packs still on the road. The problem is that it's usually in passing which makes it difficult to search for.
    Personally, anecdotally, I have 125,000 miles in my 2004 and just had my battery scanned by Eric Powers who does battery replacements. His prognosis is that the battery is still very much good to go. I'm not concerned.
    nerfer and dorunron like this.
  9. dorunron
    3,318
    1,103
    Houston, TX
    I really think the world needs to understand that the Toyota Prius is a well defined/designed product that Toyota worked very hard on in both research and development before they ever released the first Prius. The article "The Prius that shook the world" defines all of the R&D that Toyota went into before the first Prius ever hit the road. It can be found online if you diligently search for it. I think I might have a copy of the file somewhere in my hodge podge of data here...
    IMO, the battery is the least of the worries with the Prius. I would be more concerned with the transaxle and the cooling system than anything. Yes, the Prius is a expensive machine. It is due to the components that are built into the machine. A transaxle ranges somewhere around 3 to 4K at the dealer if my data is correct. Inverters are expensive also. That and all the ECU's found within the machine. The battery is one of those of those things that the Prius haters have used to make the world shy away from the technology being used in a hybrid. I myself think it stems from big oil and radiates outward from there like spokes in a wheel.
    Ron
  10. drysider
    drysider Active Member
    823
    332
    Liberty Lake WA
    Since about 225,000 Prius' were sold through 2005, that means that over 200,000 batteries have failed. This guy most be a troll....
  11. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    This is only true in the sense that 5% is closer to 90% than 0.5% is.
    But 5% is not very close to 90%
    drysider likes this.
  12. wjtracy
    wjtracy Senior Member
    11,321
    3,590
    Northern VA (NoVA)
    Please tell us where you live (USA? state?) some states have 10-yr 150k miles warranty
  13. auart
    auart Junior Member
    74
    Live in Alabama, just the normal warranty here.
  14. wjtracy
    11,321
    3,590
    Northern VA (NoVA)
    OK thanks...welcome back to Prius Chat! ...we have another UART...he is from Australia.
    UART has an intertesting current survey going on Gen2 battery failure rates. As referenced by DuRunRon, I had conducted an earlier that survey showed about 20% Gen2 failure rate among PriusChat members (more than the 2-3% Consumer Reports said), but of course we were expecting some extra bias on this site, given that people who log in here tend to be having battery problems.
    In UART's new survey, he is trying to cancel out the natural bias here by asking people if the only reason they came to PriusChat is because of battery failure . After his attempt to cancel out the bias, UART is still seeing 13% Gen2 battery failure of members here, but unfort we do not have enough survey participation.
    Traction Battery Survey. | PriusChat
    In any case, I am reminded of our church minister who once said "if the weather is good, attendance will be low...and if the weather is bad, attendance will be low...but if ..." and I forget the rest of the quote. However, the same idea may apply to Prii. Seems like a 2006 with 50k (low miles) will need a new battery soon, and a 2006 with 250k miles will need a new battery soon. But get a 2006 at about 125k miles a you might have a winner. OK that's not scientific, but that's my take on it.
  15. muirallen
    muirallen Greyman
    Saint Augustine, FL
    I have a 2007 Prius base model. There were no lights or previous indications that the hybrid system was going, but at 88,500 miles, the weird indicator light came on the dash (Looks like a little car broken in half) and the power train felt real funky. I pulled into a parking lot and got out the manual to see what the dash light meant. It said to park it, and have the vehicle towed to the nearest Toyota dealer, which I did.
    The dealer (Toyota of Tampa Bay) fixed it under warranty. The service manager said that he had only seen one other Hybrid System Failure so far, and I believe him.
    Personally I would go to a Toyota dealer for a Prius with 100 K miles or more, but only if you are able to get some type of warranty which will cover the Hybrid System. Otherwise you would probably save $ on a private purchase.
    There are diagnostic tests you can have done too, or do yourself, on (both) batteries, and the rest of the electronics in the car as well. Lots of U-Tube Vids to show you how. I would go for it, myself. We also own a 2012 Prius, and it really is a great car. (way more comfy than the '07) lots of later model ones with high miles available I would guess. ( I am not a Toyota rep, or in any way connected with any dealership, BTW. ) Good luck with your purchase, hope this was helpful.
  16. TonyPSchaefer
    14,816
    2,497
    66
    There have been several reports of Toyota dealerships replacing battery packs under warranty. Sometimes even after the warranty period has ended. We theorize that there is a lot riding on the Prius name and Toyota wants to keep their owners happy. They also do not want to give competitors any opportunities to question the batteries.
  17. muirallen
    muirallen Greyman
    Saint Augustine, FL
    Yes, Tony, I think you've hit the nail on the head. I would think that there would be quite a few people talking about it, though, if they were just generally going down like mine did, in under 100K miles.
    Just going to try reprogramming a used key fob per directions I found here on the chat. Wish me luck!
  18. whywhatever4
    whywhatever4 Junior Member
    My 2005 prius currently has over 350K on it and I'm still running with the original battery.
    I'm the original owner
    Live in upstate NY
    Odometer stopped working at 299,999 so dealer resets the Trip A odometer to keep track each oil change.
    All maintenance done at the Toyota dealership.
    nerfer, Aaron Vitolins and m.wynn like this.
  19. geeman1082
    geeman1082 Junior Member
    During a recent service visit, I asked the guy how many traction batteries they replace ... he said the only pattern is cars that have been left sitting for a long period of time (e.g., 6 months or longer, as in deployed military, etc.).
  20. Bobby T
    Bobby T Junior Member
    Chicago
    Just got a used 07. I bought one with knowledge that the traction battery has a finite life span. Was bought at 142k miles. I have an 80-100 mile work commute per day. Am interested to see what the drop in efficiency will be in cold Chicago winters.
