When do brake pads engage?
Discussion in 'Gen 3 Prius Main Forum' started by qdllc, Oct 22, 2013.
  1. qdllc
    qdllc Senior Member
    1,370
    399
    With the regenerative braking system, on the power meter, at what point are the brake pads likely to be engaging as compared to using the motor?
    I wonder because when I'm coming to a stop or coasting down a steep(er) hill, I like to apply some brake to recapture more energy but not press so hard as to be wearing on the brake pads. I'm not sure at what point the system would be engaging the brake pads for slowing/stopping.
  2. zhenya
    zhenya Active Member
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    Speedwise, I believe it is 7mph. That's what it feels like to me, someone can probably verify one way or another from specs.
  3. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Watch the small white bar on the power display. When it's full friction brakes will start to function. Up to then the pads are "just touching" the disks (in a "ready to brake" position). The GIII will use regenerative brakes down to almost a stop.
    sprtent and qdllc like this.
  4. qdllc
    qdllc Senior Member
    1,370
    399
    That's what I thought. Thanks. (y)
  5. gliderman
    gliderman Active Member
    751
    223
    The harder you push on the brake pedal the sooner you begin friction braking.
    Get a scangauge it shows the pressure on the brake pads.
    Sometimes just a little pressure will engage the brake pads even at high speed. I found if I watch the scangauge when braking I can control how much regen is occurring, generally when I am coming off the highway.
  6. BZzap!
    BZzap! Senior Member
    1,607
    877
    If you don't mind, what is the ScanGauge alfanumeric code and what unit of measurement is used?
  7. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    At high speed it takes relatively little pressure to max out the regen braking due to high current being generated (RPM). So the faster you are going the less pressure it takes to engage the friction brakes.
  8. gliderman
    751
    223
    I dont remember, it has been so long since I programed it. There is a thread about programming your scan gauge somewhere on this forum.
  9. BZzap!
    1,607
    877
    No problem... I'm lazy.
  10. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
  11. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    The specs for the Gen 3 state friction brakes applied below 7 mph. I can feel them apply when odometer is passing 7 mph.
