When do I need a service?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Rhodrons, Apr 24, 2015.
  1. Rhodrons
    Rhodrons New Member
    Chessington, Surrey
    2014 Prius Plug-in
    I just got a letter from my garage today suggesting that I was due a service as they estimated that I would by now have done 10,000 miles. I have actually done nearly 12,000 so I am overdue according to my manual. I am bemused - I would have expected such a sophisticated car as the plug-in hybrid to have been screaming at me from the dashboard that I was overdue a service (as my old Picasso did). What's going on? Is there really no built in service prompt or has it perhaps not been set up on my car?
  2. Munpot42
    Munpot42 Senior Member
    1,391
    543
    Santa Monica, Ca. 90405
    Maybe you just ignored your screen, it's mileage driven and tells you about services due every 5 thousand miles-OOPS just looked at your address, sorry, haven't a clue about Euro spec cars.
  3. Mendel Leisk
    38,644
    Assuming your Surrey is not just down the road and over the Port Mann bridge from me:
    Maybe Brit spec Prius don't have maintenance reminders? Canadian don't. Have a look in the booklets that came with the car.
    Do keep in mind: the service interval are governed by distance travelled OR time, whichever elapses first.
  4. Rhodrons
    Rhodrons New Member
    Chessington, Surrey
    2014 Prius Plug-in
    Yep-Surrey, England.
    Why would Toyota choose not to advise some markets and not others? I would thought that miles,unlike gallons, are the same in all markets - except perhaps Rome!
  5. Trollbait
    11,504
    Some markets do use kilometers.
    More likely it is just penny pinching in not having to program the interval in for smaller markets. Oil change intervals differ between. Europe is going to have longer ones than the US because of the lower sulfur in the gasoline.
  6. bisco
    49,371
    even though we get a maintenance reminder on the dash every thousand miles, my dealer estimates how many miles you've driven, and starts calling when they think you've done 5,000. they're usually wrong of course, but if they get the first one right, you do think the plug in is sending out signals.:cool:
  7. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    It is always good to read the owners manual; ALWAYS.
    I hate to say this but.......IF that really is miles and not kilometers AND they come from the factory in that area with conventional oil instead of synthetic AND the oil has never been changed since it was new........you might be WAY past the recommended change interval. Maybe 5,000 miles past or more. :eek:
  8. Mendel Leisk
    38,644
    You do have the manuals, it's all in there. ;)
  9. bisco
    49,371
    they probably figure we're not bright enough in the good ole us of a.;)
  10. Mendel Leisk
    38,644
    Honda's got a service alert that's more advanced. It counts down in percent, so you know how far you're along between services. It's apparently not just counting distances; appears to monitor several factors.
    When a service is due it shows a letter/ number combo, which you can equate to various services, explained in the owner's manual.
    Maybe wishful thinking, but should cut down on service department upsells.
    (Off-topic, can't help myself. )
  11. bisco
    49,371
    i know, it's like putting a car up on 4 ramps.:whistle:
  12. Rhodrons
    Rhodrons New Member
    Chessington, Surrey
    2014 Prius Plug-in
    I suppose it just goes to show how much I take technology for granted nowadays. I just assumed that the dashboard would scream at me like my Picasso used to. The next thing I'll find out is that I have to measure the tyre pressures rather than the dash telling me to pump them up-or will it?!
    As an aside, since the weather warmed up here in England my mpg has increased from 80 to nearly 100 (imperial gallons) which is an astonishing increase.
  13. IanIanIanIan
    IanIanIanIan Member
    152
    56
    Royal County of Berkshire, UK.
    2013 Prius Plug-in
    I wonder what this lateness will do to your guarantee?
  14. bisco
    49,371
    yes, you should check your tyre pressures regularly until you get a feel for how much leakage you have. i have learned that mine are sealed well, and only lose a couple psi in a month. so i check and refill monthly from around 39-41 to the 42/40 i keep them at. the toyota tpms will let you know when they are way below spec, which is oky to prevent an emergency, but they don't tell you the pressure or which tyre is low.
