when do people replace their Traction Battery? (includes stats)
Discussion in 'Gen 2 Prius Fuel Economy' started by Meter guy, Jul 15, 2024.
  1. Meter guy
    Meter guy Junior Member
    53
    I have a 2009 Prius with 257K original traction battery
    purchased it in 2014 at 27K
    I used to get 45-60MPG usually
    47-50mpg in town traffic at 47mph and
    55-60mpg on the interstate if i keep it at 60Mph.
    that was up to around 2016
    I keep an excel file now of all the stats to track.
    in 2017 i replaced the 12V battery and you can see my mileage started dropping at that point, the dreaded low ev state as discussed in the other thread.
    so at approx. what MPG will I get the code to replace the traction battery? you can see my MPG drops a little every year and im down to 39.22mpg right now.
    sorry for the skewed numbers, it all looks good in the writing section, just gets skewed once posted
    ..................................2016 ... 2017 ..... 2018 .... 2019 ... 2020 ... 2021 ... 2022 ..2023 2024
    tot miles driven .....27185 .... 28888... 22887 ... 19743 ... 17323 ... 23864... 23870 .. 25904
    gallons ............ ....... 503 ..... 718 ... 534 ... 484 ... 441 ...574 .. 591 ... 632
    cost .................... 1037 ..... 1621 .... 1387 ... 1179 ...929 .. 1668 .. 2191 ... 2129
    actual MPG ..........53.97 40.20 42.79 40.77 39.19 41.5 40.32 40.97
    car est MPG ..... .... 46.92 .... 43.91 .. 43.49 .. 43.71 .. 42.33 42.2 .. 41.35 40.60 39.22
    eng hours ..... ..... ... 451 ...... 539 ..... 403 .... 392 .. ...351 .... 471 .. .. 450 458
    ready mode hours ....... 934 .... 1128 ... 842 ..758 .. 750 .. 999 .. 1031 998
    #1 Meter guy, Jul 15, 2024
  2. douglasjre
    douglasjre Senior Member
    2,236
    745
    Null, NL
    I abused it and it was weak at 210k. I shouldn't have don't that
    Meter guy likes this.
    52,680
    There is no way to predict when you will get a code for the battery.
    When one of the cells falls below Toyota’s design software parameters, it will throw a code.
    You can recondition the battery now if you want to improve performance, or put the money into a new battery when you’re ready.
    srellim234, Meter guy and Merkey like this.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    Keep in mind that overall mpg is greatly affected by items other than the HV battery. I purchased a 2005 with 280k miles and one failed module in the battery. Replaced just that module and it was banging out 52 mpg for about a year before I was run off the road by an suv that liked my lane more than me and totaled the car. That car had a beautiful maintenance record with everything being performed at 2 local dealers. Even at low capacity (but not coding) the car should be able to maintain 45+ mpg. How has the overall maintenance been?
    A few things to look at:
    Brake maintenance kept up with pin lubes so they aren't dragging?
    Parking brake shoes not rubbing?
    Plugs and air filters?
    Throttle body/MAF sensor clean?
    Synthetic oil 5w-30 and decent oil filters every 5k miles or better?
    Transaxle WS fluid change?
    What kind of tires and pressures?
    Alignment?
    Any body damage or plastic pieces hanging down under the car?
    Is the brake actuator cycling like crazy? This can actually make a 3-5mpg difference.
    How much do you run the AC, that can make a 3-5 mpg difference
  5. Meter guy
    53
    i responded to each question above
  6. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    I use 5W-30 full synthetic, but i go thru a quart every gas fill
    Holy crap. 1 quart every 300ish miles? You may have bad mpg due to lack of engine power. Have you ever done a full throttle test to see how fast your car can go? You should be able to do 107ish on a flat road, limited by computer. Does the battery deplete when doing a long uphill?
    You could have a severely clogged catalytic converter (think oil burning at 1 qt/300 miles)
    or a severely blocked intake, not necessarily the manifold, but could be the plastic plenums leading into the filter. We have seen a low power engine be due to a mouse nest in the intake duct work.
  7. Meter guy
    53
    i havent done a full throttle test going that fast, but I've taken it up to 80-85 and it handles fine, but i dont spend alot of time at that speed because i dont want to stress the hybrid system.
    it has the normal acceleration that it always has had, no stumbling or hesitation, which I would think would happen if the cat is clogged.
    the engine runs the same as it always has. i purchased it with 27k miles, now almost 260K
    the MFD display shows the battery charging and discharging all the time, wether on a hill or driving around the city. thats always been a thing.
  8. bisco
    52,680
    it should do that most of the time. what it shouldn't do is quickly swing back and forth from full to empty
  9. Meter guy
    53
    what was your average MPG on the MFD at that time
  10. Skiddmore
    Skiddmore Junior Member
    Seattle
    Three Touring
    I`ve been getting 38 mpg for the ten months of owning this 08. I bought the car last October.
    It came with a transferable lifetime warranty on a freshly installed re conditioned used group of cells. The seller first purchased a recon battery November 6th of 2020 and that pack was replaced under warranty September 9 2023. Almost three years of use. I bought the car in October 2023 with 248k on the odometer.
    Mid July 2024 we get the DOA80 code and the big red triangle. Over and over again the code returns. A zero to sixty full throttle test puts the battery meter in the low purple range. So after being ignored and denied and delayed by the Green Bean warranty department for well over two weeks reality sets in. If it sounds too good.,.....
    I turned the Green Bean in to the dealer as a core and they might give me 1300 bucks for that pile of bad cells.
    After a few days of driving with a Brand New Battery from Toyota I can only say that this is awesome. The car has more thrust available. Its been cruising on level ground using the battery only, frequently with this New Battery. Only a couple times with the old pack.
    Driving with a new battery pack is pretty cool.
  11. MAX2
    MAX2 Senior Member
    1,436
    489
    101
    Third planet from the Sun
    That's a cool battery warranty!
    Toyota would have gone bankrupt long ago if they had given a lifetime warranty.
    Skiddmore likes this.
  12. dolj
    dolj Senior Member
    8,631
    4,385
    Wellington, New Zealand
    Lifetime warranty is just words on paper. Most people give up on changing batteries after the third or fourth time – sometimes in as many months. It doesn't take long for that game to get old.
    Skiddmore and Brian1954 like this.
