When do you fill up?
Discussion in 'Gen 2 Prius Main Forum' started by withersea, Jul 12, 2006.
  1. withersea
    withersea DNF is better than DNS
    1,162
    TN
    How many pips are left on the fuel gauge when you fill up?
  2. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    <div class='quotetop'>QUOTE(withersea @ Jul 12 2006, 03:33 PM) [snapback]285124[/snapback]</div>
    I wait until just after I've used 10 gallons worth, so the number of pips varies...
  3. Godiva
    Godiva AmeriKan Citizen
    10,339
    When the last one starts to blink and beep, I fill up. Sometimes sooner if it's convenient.
  4. wstander
    wstander New Member
    982
    never let it go beyond 3 pips; too many bridges, too many miles to the cheap stuff;-P
  5. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I fill up on the last one. I don't wait till it starts to blink. I did once but I don't want to risk it. That would be too embarrassing to be stuck on the side of the road in a Prius thats out of gas.
  6. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    CAN-View for the win :)
    I start to think about looking for gas at 7%, and then I'll consider going to a gas station at 5%. :D
    BTW, there are many threads on this question. Try a search.
  7. withersea
    1,162
    TN
    <div class='quotetop'>QUOTE(Presto @ Jul 12 2006, 03:45 PM) [snapback]285135[/snapback]</div>
    Thanks- I'll take a look. This may be a dumb question, but when you talk about percentages, where are you getting those numbers?
  8. zzyzx
    zzyzx Junior Member
    92
    16
    1 pip. Too many horror stories about people running out of gas here.
  9. aaf709
    3,862
    2022 Prius Prime
    Two pips generally, but sometimes at three, if I'm planning a long trip.
  10. Jeannie
    Jeannie Proud Prius Granny
    1,414
    Central New Jersey
    <div class='quotetop'>QUOTE(Zzyzx @ Jul 12 2006, 06:02 PM) [snapback]285227[/snapback]</div>
    I usually fill up sometime after I hit the 2 pip mark, but last tank I let it go to 1 pip, since I was at a point in my trip where I could fill up on the New York State thruway or 10 miles further down the road when I got into New Jersey where the gas was cheaper. I've only filled up 5 times so far. I left on my 'long trip' at 5 pips; I might have filled up 'at home' if I'd been down to 3 pips.
  11. NuShrike
    NuShrike Active Member
    1,378
    When I've driven my allocation of miles for the tank. Usually 550 miles.
  12. Cheap!
    Cheap! New Member
    1,157
    <div class='quotetop'>QUOTE(NuShrike @ Jul 12 2006, 06:17 PM) [snapback]285273[/snapback]</div>
    Last pip not blinking if I can avoid it. I did mess up once and I had to coast in.
    By the way if those are the pips, where is Gladys Knight?
  13. brandon
    brandon Member
    771
    Manhattan, KS
    Between 1 and 2 pips. Sometimes I'll fill up if I'm close to that mark and I suspect the prices will shoot up the next day.
  14. tbstout2
    tbstout2 Member
    156
    Hallieford, VA
    It depends on my roundtrip miles.
    I have no problem waiting until the pip is blinking - and then a few miles after that. However, it FREAKS my wife and daughter out when the light beeps and the ADD FUEL message pops up!! So if they are in the car I fill up as soon as the BEEP sounds off. :p
    BTW, Presto... awesome car stuff!!
  15. stanleyjohn
    stanleyjohn New Member
    269
    Higganum,Ct
    Two pips here! :)
  16. kimgh
    kimgh Member
    297
    San Jose, CA
    <div class='quotetop'>QUOTE(stanlwyjohn @ Jul 12 2006, 04:45 PM) [snapback]285302[/snapback]</div>
    Interesting. I have a completely different strategy. I fill up every other Sunday, since I can get about 2 weeks of commute + errands on a tank. Usually, 2-3 pips are still on at that point.
    I'm about to take a long road trip, and even then, I have to fill up when there's gas to be had (some of the roads are lonely Nevada roads...). But I doubt I'll let it get to 1 pip.
  17. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    <div class='quotetop'>QUOTE(mikepaul @ Jul 12 2006, 12:34 PM) [snapback]285126[/snapback]</div>
    How can you tell when you have used 10 gallons? The 04 guess guage only reads correctly when it is full or empty.
    I have never been able to put more than 9.5 in my 04, so I'm a 1 or 2 pip guy.
  18. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    <div class='quotetop'>QUOTE(withersea @ Jul 12 2006, 01:05 PM) [snapback]285146[/snapback]</div>
    CANVIEW is a module that can be installed that give MUCH more information about the parameters, conditions, and states of the car. that includes a gas gauge that runs from 0-100% in 2½ % increments. so readings would run 100,97,95,92,90,87 etc.
    before you ask where you can get one, afaik you cannot. it WAS only compatible for the 04's and 05's.
    i fill up at the same station so my fillups vary. if not going on any extended trips i usually start thinking about gas when i hit about 7% which is about 30 miles after the last bar starts to blink (it usually starts blinking at 12%)
  19. catsbox
    catsbox Member
    295
    Bellevue, WA
    2 pips usually, unless I see a really great buy on gas and am below 1/2 of tank! That has not happened but once since I bought my Prius.
  20. Jack Straw
    Jack Straw New Member
    137
