When Do You Guys Get Alignments?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by a_gray_prius, Mar 12, 2010.
  1. a_gray_prius
    2,927
    783
    IL
    I'm swapping out my winter tires for my summer set and I was wondering when you guys with 2 sets of rims did the alignments? The car doesn't wander, so I'm not sure I couldn't just do a mount and balance. However, my summer tires at 205/55/16 as opposed to my 195/55/16 winter tires. Opinions?
  2. Patrick Wong
    18,200
    6,493
    I would not bother to get a wheel alignment unless you notice driveability issues (steering pulls to one side, car feels unstable at high speeds etc.) or see unusual tire wear.
  3. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    I'd also add in driving through a lot of construction zones, lots of pot-holed roads, etc. Those pot-holes can do a number to the alignment, but you may not really notice it until it's worn out your tire pretty far.
    When I had the 5-yr Alignment warranty at NTB, I'd also go in before any long road trip. I'm debating looking into that again, since the old one ran out. I definitely got my money worth on that at the time.
    I'm usually pretty good at realizing when the car is handling differently that normal to take it in.
  4. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Yes seeing as my country is heading towards becoming a paid up member of the third world club, we have loads of big bad potholes and this has knocked my alignment right out. I noticed this when I had the car on full lock on the steering and the inside edge is pretty badly scuffed.
    Can anywhere do the tracking/alignment on a Prius or is it a specialist job at the main dealers?
    Am a little cheesed off as I hate to replace tyres when they could still have had plenty of life left in them :(
  5. Patrick Wong
    18,200
    6,493
    Excellent point. Or, if you hit a curb with a front tire.
    The zero point calibration of the yaw rate and deceleration sensors is supposed to performed after front toe-in is adjusted. This requires the Toyota diagnostic laptop, so it sounds like a visit to the Toyota dealer service dept is required.
  6. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Oh :eek:
    Well if needs must :(
  7. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    While Toyota is still in business. :cool:
  8. Sagitar
    Sagitar Junior Member
    59
    Ampthill
    Hi Grumpy - I had a full geometry check at Wheelsinmotion in Chesham when I had winter tyres fitted in November, but there was very little wrong with it.
    I haven't found many places that are really competent to do full geometry checks.
  9. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    I've had premature tire wear on two different cars (minivans) due to poor alignment - neither car had any tracking or other driving problems. Switching from winter to summer tires sounds like the perfect time to do an alignment every year, or at least get it checked for free at the tire place.
    - D
  10. a_gray_prius
    2,927
    783
    IL
    I'm bringing my car into a place I know of that does race setups so I'm sure they're qualified to do a good 4-wheel alignment (no, I'm not getting my Prius corner balanced). Does the yaw rate deceleration recalibration have to be done on a Gen2 as well or just his Gen3?
  11. Patrick Wong
    18,200
    6,493
    Yes, according to the Toyota repair manual.
  12. Walt999
    Walt999 New Member
    23
    New Mexico
    Sorry to say, but I have had my 2007 aligned at two different dealers and neither bothered to reset the steering and yaw sensors. In fact, when i asked the local dealer service manager if they reset the sensors, he looked at me like I was from a different planet and then mumbled (under his breath) "damn internet". I'm beginning to believe that the dealer's service people are somewhat comfortable with doing the mechanical work but want nothing to do with the high tech electronics in the Prius.
    Walt
  13. Patrick Wong
    18,200
    6,493
    Hi Walt,
    To promote discussion, I've attached a couple of 2G repair manual excerpts.
    What is interesting is that my 2006 Highlander Hybrid also has similar VSC, ABS etc. functionality as Prius; yet the HiHy repair manual does not require any sensor calibration after toe-in adjustment. I looked up the procedure before taking the HiHy for wheel alignment earlier this week, at a local independent.
  14. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Do I really have to get the sensors reset? Can I not just take it down the local tyre centre and get them to do the tracking? It's not too far out - but bad enough.
  15. Patrick Wong
    18,200
    6,493
    I finally realized you have a 3G model, and I don't have access to the wheel alignment details for that model. You could try the local tyre centre as an experiment, good luck.
  16. a_gray_prius
    2,927
    783
    IL
    [​IMG] If the vendor/dealer lock-in wasn't bad enough...the incompetent dealers....can I just buy the f-ing Toyota laptop??!?!?!
    Thanks for the repair manual excerpts, Patrick.
  17. macmaster05
    macmaster05 Senor Member
    4,050
    730
    I bought the unlimited Lifetime Alignment service from Firestone for $140 - now I get free lifetime tire rotations and wheel alignments. Not bad considering a tire alignment is usually $80 a pop.
    I will get the alignments done the same time I get my tires rotated, every 5000 miles.
    Or if I hit a curb, I can just bring it in. But I haven't done that - I mean bring it in. I have hit curbs, in fact I just hit one in downtown SF yesterday. DOH
  18. Patrick Wong
    18,200
    6,493
  19. Mr.Vanvandenburg
    1,328
    544
    2020 Prius Prime
    One year or never whichever comes last. Unless there is a very noticeable issue I stay away from alignments. The reason is I know there are a few good shops out there, but the adjustments involve precision, and most garages don't do that. The finest machine in the world is no good if there is a piece of dirt in the way, the parts are worn, or the machine isn't set up right. That means you have to care about your work, understand precision measurement, and take the time to do it right. I am not lucky enough to find such people.
