When does Charge Mode make sense?
Discussion in 'Prime Main Forum (2017-2022)' started by iskey, Apr 7, 2017.
  1. iskey
    iskey New Member
    22
    Ohio
    Just wondering if anyone has ideas on when it makes sense to enter into charge mode. I've been playing around with it on the highway at speeds of above 55mph. It really uses a lot of gas and lowers mpg quickly, but at the same time increasing EV range impressively. I haven't figured out yet if it's worth it. Thoughts?
  2. ChachabahPrime
    74
    Island Park, NY
    There are threads on this. The knowledgeable folks on this forum recommend using this feature sparingly, as the ends usually don't justify the means.
    52,397
    to put it simply, when it's worth it to you to drive electric vs gas. some examples are approaching a steep long mountain where having the extra power would be helpful, preparing to enter a city where only ev is allowed, desiring to sneak home silently for whatever reason, etc.
  4. Trollbait
    12,689
    Another time it might help is if you know you won't be able to charge at your destination, and the next drives will be short ones. In this case, the gas burned for charging can be offset by not going through the warm up cycle on those short trips.
    Prashanta, Insirt and giora like this.
  5. EV-ish
    EV-ish Active Member
    602
    278
    SW US
    "The choice of teen-agers and the young at heart everywhere."
    inferno, Pugwinkle, Prashanta and 3 others like this.
  6. NR427
    NR427 Member
    142
    100
    Utah
    To get some ev on a test drive. Most of the dealers I have been to can't figure out how to plug a car in.
  7. bisco
    52,397
    i did that, but not enough. it seems you need more than a couple miles of ev added to drive ev only. not sure why.
  8. EV-ish
    602
    278
    SW US
    Was this in the winter ? Perhaps the ICE had not finished its warm-up cycle.
  9. bisco
    52,397
    it was a decent day in january, maybe 40 degrees. but the idiot salesman never plugged it in like i asked him to on the phone, and started the car before we got there. it was fully warmed up with heat blasting.
    i shut off the heat, and took it out on the highway. after driving awhile, i tried charge mode, added a couple miles, and pulled off on the side streets for some stealth driving, only to find the engine came on every time i pressed the go pedal more than a quarter inch or so.
    some here have confirmed that charge mode requires more than a few miles to be available for ev, but i haven't been back for another test drive.
    EV-ish likes this.
  10. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    I wonder if using charge mode on flat at constant 50 mph to 80% EV, then using those miles back to zero EV at same speed will return similar or better efficiency than driving HV same road, distance and speed?
    HypersonicPrime and iskey like this.
  11. bisco
    52,397
    wouldn't that imply no conversion losses?
    Nic Steussy and Kramah313 like this.
  12. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    I am just saying it worth trying.
    If in CM ICE thermal efficiency is higher than in HV for same speed it may off-set losses. I know - it's a big if.
  13. bisco
    52,397
    absolutely, the more experimentation, the better.(y)
  14. ForestBeekeeper
    ForestBeekeeper Active Member
    780
    310
    Maine
    After I have driven the first 25 miles and consumed all the EV I have. Then I go to CHG mode for the next 30 miles, which gives me another 15 on EV.
  15. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    ...and your trip MPG is? I thought the point of the query is whether Charge mode is more/less efficient than simple Hybrid mode.
  16. bisco
    52,397
  17. ForestBeekeeper
    780
    310
    Maine
    Not sure yet. I want to wait to get above freezing.
  18. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    Wayward husbands at 4:00am....
  19. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    What kind of mileage does the trip computer read while using charge mode and how long does it take to get the battery back from 0 to 80% ?
    Didn't Toyota say about 30 min. ?
  20. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    Level ground 65 MPH....it will show on instant MPG
    display 39-42.8 MPG
    Load to crankshaft will stay constantly at 92% ....if there is demand for more power engine will reduce charge current to assist in electric power to the wheels
    I have not tested yet at 100% full throttle demand .....what will do....
    Standing still will operate at 1289 RPM and go from 0-80 % in 30 minutes
    I have more data that I'm obtaining just not finished with all
    pjm877, civicdriver06 and iskey like this.
