When Does Radar Cruise Control turn on the brake lights?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Gil Dawson, May 24, 2023.
  1. Gil Dawson
    Gil Dawson Junior Member
    29
    Lake Hughes, California
    I gather that the design of adaptive cruise control is intended to light up the brake lights under some conditions, but not others. Is there any way to monitor the brake lights while I am driving?
    #1 Gil Dawson, May 24, 2023
  2. Leadfoot J. McCoalroller
    8,134
    7,641
    Pennsylvania
    2018 Prius c
    Sometimes the cruise control just relaxes the throttle to slow the car.
    Other times it applies the brakes. And the brakes play by the same rules whether you or the radar is on the pedal, so the stop lamps come on.
    Gil Dawson likes this.
  3. LeviSmith
    LeviSmith Member
    111
    NY
    Yep, as mentioned, when it slows hard enough it turns on the brake lights. I've had at least one occasion where it was the right amount of dark so I could see when the brake lights were coming on while driving.
    If you really wanted to see it though it seems you'd pretty much have to either tap a brake light wire so you could run it to a light up front, etc... Or maybe you could somehow mount a mirror on the back of your car? Or maybe mount a camera back there? Nothing that seems super duper easy...
  4. Gil Dawson
    29
    Thanks, guys. I appreciate your confirming my guesses.
    Perhaps a new gizmo is worthy of invention, one that allows the driver to monitor the tail lights.
  5. Leadfoot J. McCoalroller
    8,134
    7,641
    Pennsylvania
    2018 Prius c
    My 1959 VW had that. All the other lights dimmed a certain amount when the stop lamps were on. You got used to it.
    Doug McC likes this.
  6. willyag
    willyag Junior Member
    28
    Orlando, FL
    I tested the brake lights in my 2012 plug in and the the brake lights came on satisfactorily during cruise control braking. I had installed a tow hitch and pierced the wiring for the lights but it was a several hour job to find and connect the right wires. After I had the wiring on place I managed to feed the connector around the back seat and plugged in a cheap test adapter with lights (Harbor Freight) so I could monitor it in the mirror.
  7. artieb
    artieb Junior Member
    75
    medford ma.
    2024 Prius
    Limited AWD-e
    It also had the VW included option of generator functionality
    rev the motor at idle to check charging system was operating
