When does the darn gas warning light come on?
Discussion in 'Gen 3 Prius Main Forum' started by Pugsy, Sep 12, 2009.
  1. Pugsy
    Pugsy New Member
    76
    My hybrid newbieness is showing. :p I had 450 mi on the odometer, my fuel indicator was down to the last line and I was driving around wondering if my warning light wasn't working. I didn't want to run out of gas while waiting for the warning so I filled up and it took 9 gal, meaning I still had another three in there. Strange yet exciting! :) I came from a car that had to be filled after 280 miles.
    So approximately when does the light go on? When you're down to 2 gallons?
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    At least in the Gen II Priuses, there is no light. Once the last pip is there, it starts blinking when it is low. (I have not seen a Gen III Prius yet, the other Prius in my town is a Gen I)
  3. rg5minor1959
    rg5minor1959 New Member
    Murrieta, CA
    I don't know how many gallons but I think the only warning light you get is the last bar on the fuel gauge starts to blink.
  4. Pugsy
    Pugsy New Member
    76
    I see. Well my last bar hadn't started blinking yet. Maybe I should've stuck it out to see how far I can go.
  5. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    The last pip starts to blink when you are low. I think the MID also will display a message saying low fuel, or something to that effect. Toyota's definition of low means that even once your DTE (Distance To Empty) shows 0 miles you'll still only take 10 gallons of gas meaning there is almost 2 gallons left in the tank. There is a whole thread discussing the whole topic.
    2 people like this.
  6. jay_man2
    jay_man2 jay_man_also
    1,246
    143
    Manassas, VA
    With this tank I'm hoping to be able to get to a flashing pip, then fill up with some Texaco and see how it compares mileage-wise to the Shell I've been using. Usually I fill up between 1/4 and 1/3 left, because I don't want to risk getting stuck on the Beltway in slow or no moving traffic.:p
    It's nice to know there's approximately 2 gallons left with a flashing pip (apologies to Gladys Knight). :D
  7. DrJon
    DrJon New Member
    140
    16
    Pinetop, AZ
    If your radio isn't too loud there is also a longish (3 sec) audible beep when the pip starts the flashing!
  8. SCJoe
    SCJoe New Member
    62
    Sioux City, IA
    The owner's manual says the warning starts when there is about 1.6 gallons (6L) of gas left in the tank.
  9. Blizzy_Pri
    Blizzy_Pri New Member
    Pasadena
    As everyone has stated, you'll hear a short beep and the last pip will flash. When this happen to me, my trip miles to empty indicated 33 miles.
  10. Richard P
    Richard P New Member
    Trois-Rivières (Qc)
    When it happened to me, it indicated 23 kilometers until empty but when I filled the tank, there was about 10 liters left in the tank, enough to go for another 200 km at least !
  11. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Do you guys up North know conversions in your head for Km and Miles? Every time someone posts Km and Liters I have to Google up a conversion calculator! Lol
  12. bwilson4web
    15,524
    Having run the car out of gas, by design, three times, I measured 2.1 gallons so 2 gallons is a good working number.
  13. Spartane
    Spartane Member
    149
    43
    Mississauga, Canada
    Nope -- I use google to do all my conversions directly (e.g.) I enter "2.9L/100km in mpg" into the google search box and google returns "2.9 L/100km = 81.108477 miles per gallon" (my best mpg reading achieved a couple of times on my 53 km "53 kilometers = 32.9326732 miles" trips home from work with my current tank of Shell 91 Premium gas).
  14. Blind Guy
    Blind Guy New Member
    352
    194
    Springfield Missouri
    A quick way to convert KM or KPH is to multiply the KM's (or KPH) by .6. 100 KM's is about 60 miles, and 120 KPH is around 72 MPH.
    * For us old timers who are accustomed to seeing engine sizes in cu. in., a figure of 60 when multiplied times the engine size in Liters will also roughly convert engine size to cu. in. (i.e. 5.7L = (5.7 Liters X 60 = 342, that would be the old GM 350 cu. in. engine, the conversion is not precise, but works good for giving yourself a quick idea of the engine size in cu. in.
    Multiplying .6 is a VERY fast way of getting a fairly close estimate of either distance or speed!
    David (aka Blind Guy)
    P.S. BTW, if you ever want to convert KG's to Lbs., just multiply the Kg's by 2.2 and you'll get Lbs.!
