When regenerative braking with the Gen III Prius, do the rear brakes do any braking?
Discussion in 'Gen 3 Prius Main Forum' started by Metalman, Aug 5, 2012.
  1. Metalman
    Metalman Member
    107
    17
    Summer, KY; Winter FL
    When regenerative braking with the 3rd Gen Prius, do the rear brakes do any braking?
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Only if you brake hard enough to engage friction braking. Sadly, there are no Motor/Generators hooked to the back wheels. (AWD hybrid!)
  3. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Yup, only the Highlander Hybrid can do that. THREE MGs! Read it and weep. ;)
  4. Mendel Leisk
    38,735
    Maybe the rear pads are going to wear faster? I think braking would be proportionately greater on the front, but still...
  5. DocC
    DocC New Member
    San Antonio, TX
    I watched the video I received with my new Prius Level 3. Initially light breaking is done by regeneration and does not use the breaks. It is only when you break firm/hard and/or when the "CHG" graph shows full that the actual breaks are used.
    I hope this helps
  6. Metalman
    Metalman Member
    107
    17
    Thanks for the responses. My thoughts are that most braking occurs on the front wheels and therefore all vehicles are designed to have more powerful front brakes. However, when driving on the ice with the Prius, (which I have never done because of my location) gently applying the brakes will place all of the braking energy on only the front wheels, which of course are needed to steer. I wonder if anyone has experienced a loss of steering control on slick sufraces because of using only the regenerative braking on the front wheels?
    DutchMill likes this.
  7. David Beale
    5,963
    1,981
    Edmonton Alberta
    Nope, the regenerative braking doesn't cause loss of control on ice. The vehicle stability and anti-lock systems take care of that. The Prius is very capable in winter. There is just a ground clearance issue.
    markabele likes this.
  8. Tim Bender
    Tim Bender Member
    134
    44
    you have to push the car really far before you end up with a traction deficit on the front wheels. by that point, you've already engaged the friction brakes at all 4 wheels.
  9. car78412
    car78412 Member
    284
    32
    Hudson Valley, NY
    Has anyone noticed the amount of brake dust on the rear wheels? I do not have the wheel covers installed and noticed that when washing my Prius, most of the brake dust is on the rear wheels, not the front. This will result in my rear brakes needing to be replaced before my front brakes.
  10. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    Most of my brake dust is on the front wheels. If you are seeing a lot on your back brakes it may be from rust and lack of use and not more use. Under normal driving the only time the friction brakes are used is under about 7 mph and then most of the car's weight will be on the front wheels. Most that have measured their brake pads will show slightly more wear on the front brakes. Replacing brake pads is the least of your worries as a Prius owner. You will be able to go many, many miles before having to do this.
    To eliminate the rust on the rotors, put the car in neutral while coasting to a stop a few times. Neutral disconnects the HV battery and thus the regen braking and engages the friction braking.
  11. car78412
    car78412 Member
    284
    32
    Hudson Valley, NY
    There is no rust on any of the rotors. I drive the Prius daily. Since regen is probably doing a lot of my braking, the rear pads will probably need replacement before the front. This is not a issue, just an observation.
  12. markabele
    5,084
    1,782
    Nebraska
    I'm pretty sure there are friction brakes working on all wheels at the same time when they are on. So they should all wear somewhat evenly. Someone please correct me if I am wrong.
  13. jdcollins5
    5,131
    1,338
    Wilmington, NC
    True. But more weight is on the front of the car, especially during braking, so the fronts normally wear at a slightly faster rate than the rears.
  14. markabele
    5,084
    1,782
    Nebraska
    For a hypermiler that does about as little friction braking as possible how long could you expect brakes to last?
  15. jdcollins5
    5,131
    1,338
    Wilmington, NC
    There are many on here that have gone well beyond 100k miles and their brakes are still fine. That is another advantage of the Prius.
  16. markabele
    5,084
    1,782
    Nebraska
    So is 150k or even 200k doable?
  17. jdcollins5
    5,131
    1,338
    Wilmington, NC
    I think so. Some of those that have this kind of mileage would need to respond to verify.
  18. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    I can only speak to 125k miles on my 2004 Prius, which has substantial pad life remaining.
  19. rpg51
    rpg51 Member
    200
    Vermont
    Just replaced my front pads at about 100K miles mostly highway commuting in northern new england.
  20. jdenenberg
    jdenenberg EE Professor
    3,852
    1,852
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My 2004 Prius is at 228k miles with the original brakes.
    JeffD
