When running on ICE, does the cabin heating come from the ICE?
Discussion in 'Chevrolet Volt' started by andi1111, May 31, 2012.
  1. andi1111
    andi1111 Member
    270
    63
    EU
    2012 Chevy Volt
    ... or still from the electrical heater?
    Because Ampera has a HOLD driving mode, which could, in cold winters and travels longer than 60km, be used to heat the cabin quickly in the beginning of the drive, without losing to much of battery electricity and when the cabin is warm enough, you could switch back to Normal driving mode, and electrical heating would only have to keep the cabin warm, without having to warm it up.
  2. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
    Depends on who you asked, prior to the annoucement of the HOLD button for the US model.
    There were a few Volt owners & supporters who were downright hostile when it came to this question, believing your only purpose for asking the question was really just to promote the plug-in Prius... since it would come with the HV/EV to preserve battery and allow you to take advantage for heating.
    I suspect HOLD does the same thing.
    And my guess for the reason the US market didn't get the HOLD button right away was GM's push to have Volt identified as an EV. Being able to switch to HV driving would obviously tarnish that.
  3. scottf200
    scottf200 Member
    220
    61
    Chicagoland
    Yes, they use waste heat from the ICE to warm the cabin. That only makes sense because the ICE is so "wasteful". In the current config (with a new temp in the works), if it is below 26F then the ICE will run for 2-3 minutes to heat the cabin extra quick without using excessive electricity. If you are moving at the time it burns 0.07 gals of gas and not moving it burns 0.03 gals of gas during those couple minutes.
    Keeping the climate settings on 'comfort' (vs eco) also keeps the coolant loop on thru the ICE so it stays above 115F for a long time which is where the ICE would kick back on a for a couple minutes. I have a detailed post on this on gm-volt.com.
  4. andi1111
    andi1111 Member
    270
    63
    EU
    2012 Chevy Volt
    Thank you! Do you have a link to your post at gm-volt.com?
  5. sxotty
    sxotty Member
    224
    28
    Pittsburgh
    I heard it was emissions related. Allowing consumers to change emissions profile with a button got some people's ire up.
  6. scottf200
    scottf200 Member
    220
    61
    Chicagoland
  7. andi1111
    andi1111 Member
    270
    63
    EU
    2012 Chevy Volt
    Thank you!
  8. Trollbait
    11,560
    And I believe Toyota didn't offer the EV button on the gen2 because they thought Americans were too dumb to read up on it in the manual, and didn't want to waste dealers' time on complaints on the EV not working when it is doing what it was designed to do.
    The more likely reason for both companies.
