When setting timing is Top Dead Center always the compression stroke?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by johnnychimpo, Jan 25, 2021.
  1. johnnychimpo
    johnnychimpo Active Member
    514
    112
    Monterey
    Any good videos on how to install timing chain 2010 prius?
  2. ChapmanF
    18,546
    There are, of course, two Top Dead Centers in every cycle, but in answer to the question I think you are asking, yes, any time a manual or procedure tells you to reference something to TDC, it always will mean compression TDC for cylinder #1, unless something very specific says otherwise.
    Of course while the timing chain is removed, any TDC of the crank is as good as any other, and once you install the chain with the crank at a #1 and #4 TDC and the cams in the proper #1 compression position, well, you've just made that be #1 compression TDC.
    DieselHammer and ASRDogman like this.
  3. johnnychimpo
    514
    112
    Monterey
    Thank you sir.
  4. DieselHammer
    DieselHammer Junior Member
    29
    Kansas
    This is a 2008 thread but I have a question regarding TDC. I used MrGasket video, aligned the two colored links on witness line of front timing gear and single color link on back gear witness line. I locked both cams per instruction and removed head. #1 and 4 were slightly below the highest travel … I would have to measure exact distance. I am assuming this is standard or am I mistaken?
  5. Mr. F
    Mr. F Active Member
    389
    263
    Washington
    This is what TDC looks like with an unbent connecting rod. If it doesn't get up this high for any rotation of the crankshaft, you've got a bent rod. TDC.jpg
    As long as you're within a couple of degrees of TDC, and you get the colored links into the right positions on the camshaft timing gear assembly, the camshaft timing sprocket, and the crankshaft timing sprocket, things will fall into place once you install and release the chain tensioner assembly.
    DieselHammer likes this.
  6. DieselHammer
    29
    Kansas
    Excellent! Thank you!
