When to chane Transmission oil
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Umair.114846, Jan 30, 2017.
  1. Umair.114846
    Umair.114846 New Member
    Pakistan
    when to change the transmission oil of prius?
  2. dolj
    dolj Senior Member
    7,653
    3,866
    Wellington, New Zealand
    The consensus (here) for the Gen 2 (given that Toyota's official advice is it never needs to be changed – it's a life time fill) is first change at 30,000 miles (50,000 km) and then every 60,000 miles (100,000 km) there after.
  3. Umair.114846
    Pakistan
    so u suggest that no need to change it
  4. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    No, we just say there is no official recommendation from Toyota. I advise you to change with ATF WS at 50,000 km, 150,000 km, and then every 150,000 km after that.
  5. b100
    b100 Member
    141
    73
    Netherlands
    I agree with jimbopalmer.
    Its a better late than never thing.
  6. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    656
    262
    Dodge Co. Wisconsin
    2017 Prius v wagon
  7. bisco
    49,488
    some say to do one early, like 5k, to eliminate most of the factory detritus.
  8. Mendel Leisk
    38,726
    Yeah, I would not wait for 50,000 miles before changing it. Come to think of it, with 65,000 kms, ours hasn't even made it to 50,000 miles yet. Did first change (of 3, a little overkill, even I'l admit) at the one year mark, that was around 15,000 km. One year, regardless of mileage is maybe a good parameter. It was by far the darkest in appearance. Subsequent changes I would stretch the interval.
    I have no idea how necessary changing it is, basically: for $40 and an hour of my time to DIY, I just do it.
  9. dolj
    dolj Senior Member
    7,653
    3,866
    The advice was 50,000 km.
  10. 05PreeUs
    05PreeUs Senior Member
    1,097
    563
    MSP
    Just make damned sure they use the correct fluid! It's only ~4 quarts total and 20 minutes.
