When to refuel gas
Discussion in 'Prime Fuel Economy & EV Range' started by dr_rock, Feb 12, 2025.
  1. dr_rock
    dr_rock Junior Member
    36
    Pennsylvania
    I got mu PP two months ago and haven't used much gasoline b/c I'm charging it often. I've heard that gasoline has a "shelf life" so I'm wondering how long I can go before I should be adding fresh gas? Should I run on gas until the tank is nearly empty and then get fresh gas every couple of months? Just wondering what more experienced owners do.
    51,019
    It’s all over the place. Anything in the manual?
    I’ve heard a year or so
    BiomedO1 likes this.
  3. BiomedO1
    BiomedO1 Senior Member
    2,725
    1,455
    SacTown, Ca
    the gen4 manual stated nine months to a year, but I wouldn't do that since oil changes are supposedly done annually at a minimum too. That being said, I would run the car in HV mode for one week every month. that way your burning through your gas and lubricating the mechanical bits of your motor. that also burns out gas & moisture collecting within your engine oil and prevents internal rust formation.
    Hope this helps.....
  4. dr_rock
    36
    Pennsylvania
    Thanks very much. I have been running the EV down so the engine runs bc I figured it’s good to run it once in a while, as you’ve stated. It’s a new concept for me, not using gas.
    BiomedO1 and bisco like this.
  5. frodoz737
    frodoz737 Top Wrench
    4,505
    2,426
    33
    STA-BIL would be a good idea under your circumstances.
  6. jetsam
    jetsam New Member
    17
    Badford
    2024 Prius Prime
    SE
    I routinely put half a tank of 6-12 month old gas in my last car (an ICE Toyota) when it was time to rotate my gas cans, and never had any negative consequences.
    I won't do that with this car, as the gas would then sit around for an additional 6 months plus! :LOL:
    If you're going to gas up once a year, it may be better to do it in the winter so you get winter-blend gas. Fuel stabilizer will help keep the water away from the ethanol, too.
  7. BiomedO1
    2,725
    1,455
    SacTown, Ca
    In addition to what I've stated earlier; If the engine is still running once you stopped the car. Best practices is to wait for the ECU to shut down the motor. Shouldn't be more than a few minutes, as the ECU is completing the engine warmup cycle. That's when the engine oil is hot enough to evaporate excess fuel and moisture out of your oil. You don't have to do this all the time, but it's better to let your engine warm all the way up. Again, best practices...
    YMMV..
