when to replace coolant on 100k prius C
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Denise M Dupre, Jun 11, 2022.
  1. Denise M Dupre
    Denise M Dupre Junior Member
    CA
    When should I replace the coolant on Prius C 100k miles
  2. rjdriver
    rjdriver Active Member
    409
    170
    Rhode Island
    100,000 miles, or 10 years, is the recommended first change for engine coolant. Every 50,000 miles, or 5 years, thereafter.
    bisco and Mendel Leisk like this.
    52,393
    follow your maintenance schedule for all service, ignore dealer advice and consider changing the tranny fluid
  4. BiomedO1
    BiomedO1 Senior Member
    4,146
    2,173
    SacTown, Ca
    Don't forget about the inverter coolant; separate cooling system - since you weren't clear which one we're talking about. When you look under the hood, there's two pink coolant tanks. If memory serves me; the one by the hood latch is the inverter coolant and the one on the passenger side, internal fender, is the engine coolant. You can do a litmus test to see if it actually needs changing x2.
    I'd do both of them at the same time to avoid the extra downtime.
    Hope this helps...
    valuequest likes this.
