When to replace the oxygen sensor?
Discussion in 'Gen 3 Prius Technical Discussion' started by R1CH13, Oct 7, 2014.
  1. R1CH13
    R1CH13 Member
    Michigan
    I've been looking online to see how often you need to replace the oxygen sensor for the 3rd gen Prius. I can't find anything online. Anyone know how often you replace these? Would it be around 100,000 miles or more because it's a hybrid? Also how many are there? I've heard there is 2 and some say there's 4. Thanks
  2. CARspec
    CARspec Junior Member
    53
    Eden Prairie, MN
    2014 Prius Plug-in
    When they fail. Don't worry about it until they do, and don't replace any more than the failed unit if one does.
    You car has one Air-fuel ratio sensor and one oxygen sensor. The former has more range than the latter.
  3. tv4fish
    tv4fish Member
    202
    46
    And if/when you replace either one - make SURE you order and get the correct one - a lot of these "aftermarket" suppliers don't know the difference between the 2. (Yes, the voice of experience).
