When to switch to Synthetic oil?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Johno, May 20, 2004.
  1. Johno
    Johno Junior Member
    71
    Chester Springs, PA
    It has been my experience with engines that it is better to use regular oil when an engine is being broken in. At what point do you switch to synthetic. My guess is 600 to 1,000 miles.
    Also, would it be better to use the Toyota oil filter or is there an equal, less expensive alternative?
    Thanks.
  2. richard schumacher
    7,663
    1,038
    United States
    The subject is practically a religion. It sure would be nice if someone could post references to serious evidence. (Me, I'm just gonna put in Mobil 1 at the first scheduled oil change, use Toyota filters, and not worry about it.)
  3. Johno
    Johno Junior Member
    71
    Chester Springs, PA
    Thanks Richard. I was thinking the same. Is the first oil change 5,000 miles?
  4. fred
    fred New Member
    235
    nashville
    im with you richard. also just to back it up our prius guru, john, switched at about 1000miles.btw my mercedes warrantyfor engine is voided (yes its true if i dont use mobile1) reason as i interpret it has to do with oil surging or bubles or some such thing iknow you love it when i talk tecno
  5. tag
    tag Senior Member
    2,526
    Chicago
    5k miles or 6 months according to Toyota for the Prius.
    I don't think I'm going to wait that long, though. Can't really go wrong following John's procedure, as far as I can tell. :)
  6. mdacmeis
    mdacmeis Member
    133
    Michigan
    2018 Prius Prime
    I would strongly encourage everyone wanting to switch to synthetic oil to wait a minimum of one and generally two oil changes before they switch. The "break in" period, while a mystery in actuality, depends on friction to wear the high spots from components, resulting in smooth, uniform, or a least mated, surfaces. This is critical in the cylinders, but is also important in bearings. Many manufactures still use a break in additive, although some enter the system as a result of "pre-lubes" used during assembly. Many an engine manufacturer in the automotive and marine industry has stressed that best overall performance, life, and economy will result when the initial oil change is done at the scheduled interval. Many also have encouraged waiting one additional interval to allow for better component run-in. When you consider the quality of today's motor oils, there should be no concern about doing this. Thereafter, the use of synthetic oils tends to greatly reduce start-up and cold temperature wear resulting from poor cold oil flow. The Prius engine runs in a manner that tends to reduce stresses, however any engine will benefit over the long term from using synthetic oils. The problem is that with todays engines, there is little data available to support this since conventional oils are so good and modern engines are so forgiving. The laboratory oil tests, conventional vs synthetic, however speak for themselves.
  7. tag
    tag Senior Member
    2,526
    Chicago
    Okay, I'll do that, then. :lol:
  8. daniel
    14,487
    1,518
    Spokane, WA
    For what it's worth, I read on one of the synthetic motor oil manufacturers' sites that you don't have to wait for a break-in before switching to synthetic. They claim you can use it on a brand-new engine.
    However, I have seen no convincing evidence that synthetic actually makes a difference. I'd like to see a proper scientific study showing an improvement in mileage, or longer engine life in this particular engine (which runs so much less, and uses its own unique low-stress starting routine).
  9. richard schumacher
    7,663
    1,038
    United States
    True (see the Mobil 1 website for references), and "I agree". I will use Mobil 1 not because I expect any significant increase in performance, economy, or engine life, but because I want to use as little petroleum as possible. Which is pretty much why I bought a Prius in the first place.
  10. daniel
    14,487
    1,518
    Spokane, WA
    So what's Mobil 1 actually made of? And how much petroleum goes into the manufacture of it? (It must take energy to manufacture.) And at one oil change every 5,000 miles, are you really using less petroleum?
  11. Lectricar
    Lectricar New Member
    98
    Glenmoore, Pennsylvania
    I posed the break in question to toyota. they stated that there was no reason to wait to fill with synthetic.
  12. ifftster
    ifftster New Member
    77
    St. Petersburg, FL
    I posted the synthetic question to Toyota as well. The response was to wait until the first oil change, and that once I go synthetic I could never go back. Although I don't believe the latter.
  13. daniel
    14,487
    1,518
    Spokane, WA
    Now that you mention it, I think it was on the Toyota site that I read that: synthetic once, synthetic forever. Note that whether or not there are technical reasons for it, you could void your warranty by disregarding their injunction. But I do believe them. I have heard this before, and I see no reason for Toyota to lie about it.
    And I'd still like to know what Mobil 1 is actually made of. And if the answer is "polyoleophenylestereloloeopropolyglycolomolicolacetate," then I want to know what that is made of! And how much petroleum goes into the manufacturing process. (Although if you burn 100 gallons of gas between oil changes, even plain old dino oil is adding a pretty small amount of petroleum to your consumption.)
  14. jamarimutt
    jamarimutt New Member
    985
    I am pretty sure that using sythtetic oil in the Prius 76 hp, 5000 rpm, low-stress starting, frequently off engine, offers no advantage.
  15. Brian
    Brian Member
    480
    Bakersfield
    I am going to switch to synthetic at the 5,000 mile service mark.
  16. Danny
    Danny Admin/Founder
    7,093
    2,107
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Not the case - check out the myths over on their website:
    http://www.mobil1.com/why/myths.jsp
  17. daniel
    14,487
    1,518
    Spokane, WA
    That site does not actually say that you can switch back to dino. They just say synthetic won't void your warranty. Toyota says it's fine to use synthetic, but that if you use it once, you must use it forever. So switching back to dino after using synthetic violates Toyota's express recommendation. And that might void your warranty.
  18. Medved
    Medved New Member
    128
    Willowick, Oh
    FYI -
    I spoke with my Brother, Toyota Mechanic, about this very item. He said there was no problem switching back and forth. He has been with Toyota for over 15 years now. His main concern, in regards to oil, is keeping the oil/synthic clean. Change it reguarly. He also made the comment about using a GOOD oil filter and AIR filter. This is how contaminants "get in" He recommends sticking with Toyota brand filters. He has always taken car of my cars, and I have never had any problems.
  19. Danny
    Danny Admin/Founder
    7,093
    2,107
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    This is what I was referring to:
    Q: I need to flush my engine before switching to Mobil 1.
    A: No special preparation is necessary when switching from conventional motor oil to Mobil 1 with SuperSynâ„¢.
    That lead me to infer that you can swap back and forth without having to flush the system, therefore it would be ok to do.
  20. jamarimutt
    985
    If it ain't broken, don't fix it. Does the Echo need synthetic oil? The Prius needs it even less.
