When you fill up gas tank...
Discussion in 'Prius c Fuel Economy' started by Justin Hargrove, Mar 17, 2018.
  1. Justin Hargrove
    Justin Hargrove New Member
    16
    Hesperia ca
    2015 Prius c
    When you fill up your gas tank, how many cruising miles does your car say? For the most part mine says 370 miles unless I add a bit more after gas pump stops. The most I’ve seen was 389 miles.
    Starship16 likes this.
  2. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    I have been unable to get my car to talk to me. However, when tanking up I always get over 100 mpg and try for a 1000 mile/ tank useage. the last three times were 104, 106 and 96. The mpg reading on my dash generally
    displays about the same, usually a bit more, like 110 mpg. I tend to agree with the manual system, although it’s fraught with errors, like: how full is full? Hope this answers your question.
  3. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Not at all. He has a C.
    The information about your model does not apply.
    Ragnaroktopus and roadrunner like this.
  4. Andyprius1
    2,327
    859
    Cool CA
    I noticed that, his post came to me by Email. So I answered it from my perspective. I should think the OP may notice what I’m driving. Anyway I notice that unlike how it was before the last change, everything is discombobulated with very little order. I also like to read the real action. The Prime is so boring.
  5. davids45
    davids45 Active Member
    104
    132
    Chatswood, NSW
    2016 Prius c
    G'day,
    I usually see about 680km. Feel free to practice your x16 tables (as a 1.6 divisor) to get the rough equivalent miles ;) .
    I expect this is a safety-first under-estimate, given the actual distance depends so much on how the car is driven, the roads, and the weather. City-only driving gives me more than this before the km figure gets to near 0 (often still have a couple of blips on the fuel gauge), motorway-interstate driving is much more consumptive/expensive so this full-tank estimate is about right for a >600km country trip.
    David S.
    Andyprius1 likes this.
  6. Andyprius1
    2,327
    859
    Cool CA
    680KM X .625 = 425 miles So you are doing a bit better than Justin.
  7. Andyprius1
    2,327
    859
    Cool CA
    As David 45 said, it’s all about conditions, weather, air pressure, temperature type of traffic. and lastly but not leastly, all these Prii calculate your future mileage based on your past driving so that number indicating range
    is all very subjective. It’s a guess.
    However, you can change it and increase that # by better driving. Meaning, slower speeds, steady speeds, more gliding, etc.
  8. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    If I remember correctly, my last fill up was 412 miles. I did see those low numbers you mentioned estimated myself during the winter. But now that it's getting warmer, I cleared my vehicles history to give me a somewhat more accurate estimate.
  9. pulltab
    pulltab Junior Member
    26
    Poway, CA
    2015 Prius c
    Mine also varies by many miles... sometimes after a "fill up" showing 393...then other times up to 405...seemingly like I am putting the same amount of gas in... don't know why it fluctuates so much... I understand it is just an "estimate", so not really interpreted as gospel on the actual mileage left.
  10. uber2016
    uber2016 Junior Member
    US
    Three Touring
    dubit and Andyprius1 like this.
  11. davidc83
    davidc83 Member
    113
    50
    Scottsburg, Indiana
    2015 Prius c
    I have noticed my cruising range after fill-up is based on my previous mpg on the previous tank if gas overall mpg
    Z917VL ?
  12. Andyprius1
    2,327
    859
    Cool CA
    The gas tank fill up will always vary, nothing can be done except to average all your readings.
    In ref to post 9.
    #12 Andyprius1, Mar 30, 2018
  13. Mendel Leisk
    38,643
    I've never looked. (n)
  14. SwhitePC
    SwhitePC Active Member
    495
    214
    ca
    In cold weather, it would read 330s (+ the 30-50 last 1.5gal that I know the car doesn't show once it hits 0 and beeps)
    AND
    In hot weather, I've had it read near 400s (+ the 30-50 last 1.5gal after the 0 beep)
  15. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    I've seen as high as 485 (before the 1.5), but that was when I was doing my old commute and getting 60 mpg tanks.
  16. mohsin
    mohsin Member
    91
    61
    Dubai, UAE.
    2014 Aqua
    My car shows 780 ~790kms
  17. mohsin
    mohsin Member
    91
    61
    Dubai, UAE.
    2014 Aqua
    Strangely this time it showed some 930kms. I presume it is calculated from the present avg.
  18. mohsin
    mohsin Member
    91
    61
    Dubai, UAE.
    2014 Aqua
    Every time its different. Most probably it derives it from the averages.
  19. Andyprius1
    2,327
    859
    Cool CA
    My miles per tank: always over 1000 miles.
    The question on calculating is: How full is full, did you spill some gasoline? What is lost from evaporation?
    Do you always stop pumping at exactly the same fill-up. are you sure? prove it.
  20. Mendel Leisk
    38,643
    You obviously do not stop pumping at the same degree of fullness. But it is not critical to do so: a slightly fuller fill on one tank will balance out on the next. The more consecutive tanks you calculate, the more deadly your overall fuel economy calculation becomes.
    If you stop at first shut off you won't be spilling gas, and the tank is well sealed: evaporation is minuscule.
    Starship16 and Andyprius1 like this.
