Where Are My Keys?
Discussion in 'Gen 3 Prius Main Forum' started by Rebound, Aug 20, 2013.
  1. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
    My wife drove my Prius Plug-in while away and she lost the keys. But the car will still start and stop (Power on and off). So the keys must be inside the car somewhere, right? I can drive from home, switch it off, and it will start again. I've looked everywhere I can think of -- in & under the seats, I took the glovebox out, removed the rear seat... no luck. Any ideas where set of keys can lose themselves inside a 2012 Prius?
    Thanks!
  2. retired4999
    2,652
    625
    Eau Claire, Wi.
    Coffee cup holders, I did this could not see it!
    Under flying bridge.
    In cubby in right arm rest.
    Door cup holders.
  3. ewxlt66
    ewxlt66 Active Member
    535
    186
    Dana Point, CA
    Frustrating!
  4. Rebound
    3,964
    2,613
    Portland, OR
    Thanks. Tried all that and much more.
  5. retired4999
    2,652
    625
    Eau Claire, Wi.
    Did she leave a coat or some other clothing with pockets and a fob inside?
  6. fuzzy1
    10,174
    Do you have a second fob? If so, try to use it to lock the car remotely from outside. If it refuses to lock, then the first fob is still inside.
    frodoz737 likes this.
  7. retired4999
    2,652
    625
    Eau Claire, Wi.
    Under a floor mat?
  8. Rebound
    3,964
    2,613
    Portland, OR
    No. If I try to lock the door, it won't let me; it reports that the key is detected in vehicle.
    She'd put her keys in the console and noticed them missing when she'd returned home. She was driving with my 11 year-old daughter, who's disabled and does not speak. She could have put those keys most anywhere.
  9. retired4999
    2,652
    625
    Eau Claire, Wi.
    Your Daughter did a good Job! Could she have got in the back and put the fob under our little storage area in the rear by the big battery? Under the floor.
  10. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    One thought: The fob should be blinking its tiny red LED while its in the vehicle. Go out when its as dark as possible and look for the light?
    Edit: I just checked mine and it flashes once every 5 seconds while its in communication with the car.
    Rebound likes this.
  11. retired4999
    2,652
    625
    Eau Claire, Wi.
    Sun glass holder in the roof?
  12. BZzap!
    BZzap! Senior Member
    1,607
    877
    A lot of times people drop or place the keys down while loading and unloading cargo in the back. I know, I've done it before. Also, the area down the sides of the seats is a good place to misplace items. Take a good flashlight and look under the seats along the seat rails. I thought I had lost my iTouch until after 6 months I found it in the back storage pockets of the seats. Good luck... and be sure to let us know where they turn up.
  13. Rebound
    3,964
    2,613
    Portland, OR
    Solved!
    They fell between the front console and the driver's set. In the Plug-in Prius, there's a toolbox beneath the driver's seat which has a deceptively wide lip. Here's a photo. The entire keychain, with three fobs, was hidden along the left edge of the storage box in this photo.
    ftl, JMD and burstaneurysm like this.
  14. El Dobro
    El Dobro A Member
    6,979
    3,214
    That sure beat having them dropped down in the defroster. :D
    Rebound likes this.
  15. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
  16. retired4999
    2,652
    625
    Eau Claire, Wi.
    Glad you found them!(y)
  17. Rebound
    3,964
    2,613
    Portland, OR
    And my special thanks to you!
  18. retired4999
    2,652
    625
    Eau Claire, Wi.
    Your Welcome!
    I did not win the game! You did! Congratz! (y)
    I will have to remember how easy it is to lose the keys and your hiding spot! :D
  19. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    My fob is always in my pants pocket, so unless I lose my pants I should be okay! :ROFLMAO:
    Glad you found them...
  20. SuperGLS
    SuperGLS Member
    200
    52
    Washington DC
    ^^^If you lose your pants you probably have bigger problems than lost keys.
    This thread made me laugh, thanks for sharing.
