Where can I find this tool?
Discussion in 'Fred's House of Pancakes' started by George W, Feb 29, 2020.
  1. George W
    George W Senior Member
    911
    511
    San Antonio
    This is a corner of a Ryobi 40 volt lithium battery pack. It has developed an issue where the tool it's powering will suddenly stop under load, but restarts after short rest.
    I'm guessing that one of the internal cells is failing. Now that I have a hobby charger capable of lithium ion balancing, I'm interested to see if the weak cell could be recovered.
    I've seen these type of security bits before but I'm not sure where I can purchase one to access this battery case.
    These batteries cost $100, and I've actually discarded one before I knew anything about Hobby Chargers. I'd like to try and not have to discard this one. Thank you.
  2. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    tamper-proof Torx This set might work.
    George W likes this.
  3. George W
    911
    511
    San Antonio
    Thank you for that reference. I see that a Harbor Freight Tool in my neighborhood shows a similar product. I'm going to take this battery over there and if it doesn't fit I'll be ordering that one off of Amazon. Thank you so very much.
    dig4dirt and Prodigyplace like this.
  4. Prodigyplace
    11,696
    11,318
    Central Virginia
    They have a coupon for 30% off all items under $10 (limit 5 items.)
    7 PC. STAR TAMPER PROOF KEY SET
  5. fuzzy1
    10,165
  6. RRxing
    RRxing Senior Member
    2,519
    1,790
    NEPA
  7. bisco
    49,398
    i've had the same problem with 18v ryobi's. will be curious to see if you have any luck.
  8. George W
    911
    511
    San Antonio
    First breakdown of ONE + for you.
    I purchased the 100 piece security bit set from Harbor Freight. The tamper-proof Torx bit number T10 fit the OnePlus perfectly. Of the four screws, one of them is filled over the top with a barrier that you have to dig your way through. Took me about 10 minutes with an exacto blade.
    Seems like a standard form factor .Anyway, next task will be to figure out how to apply this information to a hobby charger
    Thank you everyone for your help. I'll post the results as soon as I'm able to work through a few Cycles
    bisco, Prodigyplace and fuzzy1 like this.
  9. Mendel Leisk
    38,656
    I think this style is really hopeless for extraction. Not clear from the picture, but looks like the kind where the 3 and 9 o'clock faces are vertical (for install), and the bottom of the socket ramps up to the surface at noon and 6 o'clock, making it impossible to unscrew.
    They're like a pop-rivet: might as well just drill them out.
    Prodigyplace likes this.
  10. Prodigyplace
    11,696
    11,318
    Central Virginia
    That is why the notation "One Way". ;)
    Trollbait and Mendel Leisk like this.
  11. hill
    8,159
    in such instances, one wheels their tig welder out and heli-arc'sa a nice Fender washer on top standing up. Now you have a nice surface for a crescent wrench to back it out with. Much easier than drilling it out & running a reverse spiral Helicoil into it.
    #11 hill, Mar 1, 2020
    Prodigyplace and Mendel Leisk like this.
  12. Mendel Leisk
    38,656
    Turn it into a thumb screw. :)
    hill likes this.
  13. George W
    911
    511
    San Antonio
    Bisco, the results are going to take a while. Of the five batteries, four of them are near zero volts. One battery had a little over two volts in it and this is the one that I'm starting with first.
    There is something strange going on with this SkyRC B6AC charger. It would not detect the lithium-ion battery. I went to the RC forums, and they suggested putting some energy into the cell, enuff to get it recognized. The procedure is not exactly recommended, but did get the cell 'recognized' and on a charging profile.
    We'll see what happens.
  14. bisco
    49,398
    any idea how old the battery is?
  15. George W
    911
    511
    San Antonio
    29th week of 2012, so mid July 2012. This is a battery I purchased for my father (who lets his tools set for long periods of time).
    For a 1300 mAH battery it's showing a capacity of 1019 mAH after 2 cycles. Going to give it one more cycle.
    bisco and Prodigyplace like this.
  16. George W
    911
    511
    San Antonio
    The results are in.
    4 of the 5 Li -Ion cells were completely dead. The only surviving cell charged up to a final capacity of 1,014 mAH, but is currently only holding at 3.27V.
    At first I thought perhaps the battery management circuitry might be influencing the readings so I went further and completely disassembled the One +. Unfortunately, the individual cells measured exactly the same as they had before, so nothing gained by that exercise.
    Since I am not the hobbyist who collects rechargeable cells and retasks them, I don't know if this was a worthwhile effort. If I had newer battery packs that had seen frequent use, maybe the outcome would be more positive.
  17. bisco
    49,398
    Thanks for trying!
    Mine run a little while and stop. Wait a few seconds, and it does the same thing.
    I can usually complete the task, but always thought it was a loose connection.
  18. Trollbait
    11,514
    At least now you can just order generic cells for replacement instead overpaying for a new pack from the tool company.
    George W and Prodigyplace like this.
  19. George W
    911
    511
    San Antonio
    True, but the time needed to split the battery holder, and re-solder the leads could be the deal breaker.
    I have yet to open the 40V pack. Unlike my Dad's One + kit, the 40V gets regular use, so maybe there is only one weak link that could be replaced. If you interested, I will post that breakdown.
  20. George W
    911
    511
    San Antonio
    I don't have pictures to show, but I found the battery pack to be well-made. The solder points were all smooth and shiny, the connection tabs are solid. Nothing on the circuit board displayed corrosion, erosion, or heat stress. Not sure if Li-Ion reacts well to heat and humidity, but there are plenty of both in SW Texas.
