Where can I get a deep cycle battery to use as the 12 volt battery?
Discussion in 'Gen 2 Prius Technical Discussion' started by wbs887700, Feb 15, 2021.
Thread Status:
Not open for further replies.
  1. wbs887700
    wbs887700 Junior Member
    74
    I need to replace my 12 volt battery and I want a deep cycle battery because I have a 1500 watt power inverter connected to my 12 volt battery that I use to power high-powered electronics.
    Can you post a link to one (or more) that you know of? I want it to fit where the OEM battery goes, and I want the lid to fit on top. Also, how do you wire it? Like, how do you connect the positive and negative terminals to the car?
    I want the biggest deep cycle battery (the most amp hours) that I can fit in the battery cubby.
    48,930
    no idea. check with a marine supply company?
    the battery cables connect like any car, but they won't fit a standard battery, you would need to cut them off and install the correct size.
    also, you need a battery size that will fit the pan and total area, or do some sheet metal work.
    safety wise, you might want a battery that won't explode in a rear end collision.
  3. Tideland Prius
    16,051
Thread Status:
