Where do I put the fob?
Discussion in 'Gen 3 Prius Main Forum' started by Tickwood, Jan 31, 2010.
  1. Tickwood
    Tickwood Active Member
    334
    101
    San Diego
    2020 Prius Prime
    Yesterday when I took the car to the car wash I tried to put the fob into a dashboard slot like I had in my 2004 I discovered there isn't one. Or at least I can't find any and I can't find any mention of one in the owner's manual.
    Am I missing something? What do you do with the fob?
    Thanks
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Same place you put it when you drove to the car wash. The fob only needs to be inside in the driver's area. You must already know this, or you wouldn't be able to drive your car. Perhaps I'm missing something about your question.
    If you are questioning what to do if the fob battery fails, then all you need to do is hold the fob up to a spot on the dash. I believe the spot is the power button, but I can't say for sure without looking it up.
    Tom
  3. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Tom is correct. The Gen3 internal sensors are stronger. They now recognize the fob when it is on the deck.
  4. Tickwood
    334
    101
    San Diego
    2020 Prius Prime
    My point was that I did not want to leave the fob lying loose where it can get lost or damaged. Tomorrow I have to have the car in the shop all day for minor body work and I don't want to leave it lying loose.
  5. mitch672
    mitch672 Technology Geek
    1,077
    197
    Randolph, MA
    I would sugest leaving it in the cupholder, and tell the repair shop to remove it if they have to park the car outside, it is just like any other car key, except its electronic. Most shops are well aware of smart keys by now.
    Mitch
  6. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    The cupholder would be the best place.
  7. patsparks
    10,664
    567
    Adelaide South Australia
    Why not leave it with the service writer?
  8. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    That what I was thinking:confused:
  9. GreenGuy33
    GreenGuy33 Active Member
    534
    29
    Rhode Island
    If you are going to an auto repair shop, I'm sure that you will first have to check in. When doing this, hand over your key fob like you would your key for any other car. Now it is their responsibility.
