Where do modules tend to fail, within the HV battery, for you? Any particular side?
Discussion in 'Gen 2 Prius Main Forum' started by rogerdpack, Oct 9, 2024.
  1. rogerdpack
    rogerdpack Junior Member
    62
    Enoch, UT
    I'm looking for any patterns in module failure. Is it random? Closer to the ECU? Toward the middle? (fan is to the right, the opposite side of the ECU, in gen2 FWIW). Also ever had any fail right on an outside edge before?
    Thanks!
    #1 rogerdpack, Oct 9, 2024
  2. rogerdpack
    62
    Enoch, UT
    I've had one fail right in the middle. Another near the ECU...lost cells I think.
  3. Leadfoot J. McCoalroller
    7,824
    7,290
    Pennsylvania
    2018 Prius c
    I keep reading about more problems in the middle of the pack than anywhere else.
    Brian1954 and rogerdpack like this.
  4. pasadena_commut
    pasadena_commut Senior Member
    2,215
    661
    Southern California
    If it wasn't such a PITA it would probably make sense to rotate the module positions periodically so that on average over time they all are exposed to a similar temperature profile. That would probably keep the pack in balance a bit longer. In this world though it is a PITA and it doesn't really make sense to do all that work at the needed intervals just to eke out another 10% life on the pack, which will pay off, maybe, a decade later.
    I hope and suspect that liquid cooled packs in EVs have less of a problem with varying temperature profiles. Certainly they are much better than air cooled packs in this regard. Or at least the Nissan Leaf demonstrates that air cooling an EV pack is not a great idea.
  5. rogerdpack
    62
    Enoch, UT
    Just for fun I looked for images of "Dr. Prius" to look for temperature readings of the batteries and sure enough, usually temp1 is coolest, temp3 is 1 degree higher than that, and temp2 tends to be 4 degrees (celsius) higher than that...
    And I also wish somebody would make an aftermarket module case that allowed hot swapping easily... :)
  6. rogerdpack
    62
    Enoch, UT
    I'll collect random reports in this thread. Here's one of somebody losing a cell in the middle of the pack: Changing bad module on hybrid battery without balancing? Please help! | PriusChat here's another with two from the middle: Gen II Prius Individual Battery Module Replacement | PriusChat here's one from the middle but interestingly the two "right on each edge" are also weak: Gen II Prius Individual Battery Module Replacement | Page 3 | PriusChat also end ones "weakened" mentioned here Gen II Prius Individual Battery Module Replacement | Page 57 | PriusChat (and another middle failure). Another mention of #1 and #28 being weak here: Gen II Prius Individual Battery Module Replacement | Page 86 | PriusChat another middle dead with end weird here: while i have the HV battery out of my gen1 | Page 6 | PriusChat another with a dead middle, ends weird: Replacing Modules | PriusChat
    I haven't heard of the ones on the end actually dying though, just being more degraded (?) I may have had some luck doing a recondition on one before FWIW...
    #6 rogerdpack, Oct 10, 2024
  7. rogerdpack
    62
    Enoch, UT
