Where Does Energy Come From?
Discussion in 'Prime Main Forum (2017-2022)' started by Kan, Apr 11, 2024.
  1. Kan
    Kan Junior Member
    35
    Las Vegas
    2022 Prius Prime
    When putting car in HV/EV mode to self charge battery, where does charging energy come from? Is that setting using gasoline engine to charge battery? If so, I'm not seeing the point of saving gas then. I also noticed engine revved really high when I used that setting and tried to get on highway, so I immediately disengaged it.
  2. Trollbait
    11,560
    Yep, uses gas to charge.
    There might be some fringe cases where it saves gas overall, but it is more about adding EV range for later. Either because charging won't be available at the destination, and later trips can be covered by EV, or you're heading to an ICE exclusion zone, like some European cities have.
    Kan and bisco like this.
  3. fuzzy1
    10,169
    It is for when you need EV to sneak home very quietly, without waking up the gf ...
  4. schja01
    schja01 One of very few in Chicagoland
    1,746
    1,162
    Chicagoland
    2018 Prius
    Sales people should be instructed in how t use “charge mode” so they can demo Primes in EV mode because they never seem to have a Prime charged up when you want to do a test drive.
