Where exactly Cylinder Block Drain Cock Plug?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kknguyen1168, Aug 8, 2013.
  1. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    hi all
    can anyone tell me where exactly Cylinder Block Drain Cock Plug? I can not find it, pics would be nice if you had it. I tried to change my water coolant.
    V/r
    Khoi Nguyen
  2. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    hi all
    Seriously nobody had done coolant change yet for Gen 3 Prius ??????
    V/r
    Khoi nguyen
  3. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,601
    1,691
    Bay Area
    when you're doing a coolant change for the engine, you don't need to remove the engine block plug
    1st, you remove the cock plug
    2nd, refill it from the reservoir
    3rd, put it into inspection mode.
    As for the plug, I don't even know where its at, but that's the procedures they do at the dealer.
  4. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    Nutzaboutbolts
    so what you telling me that even at the dealership they DO NOT know where is Cylinder Block Drain Cock Plug?? and that what they told you what they did?
    V/r
    Khoi Nguyen
  5. NutzAboutBolts
    1,601
    1,691
    Bay Area
    From what I know, they only do a drain and refill at the dealership, they don't remove the engine coolant plug, they remove the radiator cock plug and then refill it at the reservoir.
  6. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    Nutzaboutbolts
    That strange, because that is the requirement when you change the coolant, what happen when we request to do that!!! are they going to lie that they did!!!, it only do this every 100k why don't we do it right from the start??
    V/r
    Khoi Nguyen
  7. NutzAboutBolts
    1,601
    1,691
    Bay Area
    Where did you read that its a requirement to drain out the coolant from the engine? I know most car's do that, but for the Prius, it didn't say that.
  8. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    Nutzaboutbolts
    It is in procedure in dealer manual book, I will send you a copy
  9. NutzAboutBolts
    1,601
    1,691
    Bay Area
    thanks! I just checked it out, it looks like the Cylinder Block Drain Cock Plug is on top by the cylinder head? not sure how it would look like.
  10. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    I can not find it, if you do please take a pics and post in here please.
    V/r
    Khoi Nguyen
  11. NutzAboutBolts
    1,601
    1,691
    Bay Area
    will do lolz, if not, I will let you know as well.
  12. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    thanks my friend, surprise me that nobody in the forum know about this.!!!!:(
  13. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    The cylinder block drain plug is on the back side of the engine next to the fire wall. IIRC it is about halfway up the block and a little closer to the passenger tire.
    The picture in the manual is not very good but does get you in the general vicinity. The HINT tells you that it is on the back side of the generator (engine).
    I removed mine when I changed the coolant, following the repair manual instructions.
    tumbleweed likes this.
  14. kknguyen1168
    kknguyen1168 Member
    453
    35
    san diego
    Jdcollins5
    thanks, do you mind if you can take couple pics show exactly where it located? still very hard to find and it helpful with pics.
    V/r
    Khoi Nguyen
  15. jdcollins5
    5,131
    1,342
    Wilmington, NC
    I will be glad to the next time I have the engine undercover off but do not know when that will be. I just changed oil and filter this weekend.
    You have to access the drain plug from below..
  16. freemandp
    freemandp Junior Member
    Canonsburg, Pennsylvania
    My chilton manual is saying there is a tank to keep the coolant warm when the car is off. I'm thinking that is only on the gen II prius. Is there a tank on the gen III? I also would appreciate a picture of the drain plug. The repair manual and the chilton book are so different. The Chilton is trying to put all the models in one book. Makes it pretty confusing. You get what you pay for I guess. Where can I get the Toyota repair manual?
  17. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    You are correct, the coolant thermos was Gen 2. For Gen 3 they used the heat exchanger in the exhaust system to speed warm-up.
    Try a searching ebay for 2010 factory manuals sometimes you can get one on a CD for $10 or so, or you might find one to download.
  18. freemandp
    Thanks. I'll check it out. Just finished the engine and the inverter change. I found the drain plug. It's a little copper plug 10mm wrench required on the back of the engine all the way over on the passenger side about 6 inches from the bottom of the block. It is recessed into the block a bit an hidden pretty well. It has a tube right under it to put a hose on to direct the coolant. See pic below.[​IMG]
    Drunkskier and The Critic like this.
  19. gliderman
    gliderman Active Member
    751
    225
    Did you access it from under the car easily?
  20. gruzinchik
    gruzinchik Junior Member
    Georgia
    hello , anybody knows where are this cylinder block drain cock plug? i try to find it but .......
