Where I hook up a powered subwoofer with the standard head u
Discussion in 'Gen 2 Prius Audio and Electronics' started by ifogel, May 1, 2005.
  1. ifogel
    ifogel New Member
    32
    New York, NY
    I have purchased a Kenwood WooX KSC WA62RC amplified subwoofer and would like any information anyone might have as to where to hook it up to with the Prius standard head unit. I will first try to fit under the passenger seat - if it doesn't fit there I'll go into the well under the trunk floor.
    Any suggestions will be appreciated.
  2. frenchie
    frenchie Member
    150
    48
    France, not far from PARIS
    Re: Where I hook up a powered subwoofer with the standard he
    this sub works perfectly under passenger seat.
    you do not need a level adapter because this sub has already a high level entry.
    The signal from right rear door is enough.
    You can get power from behind the big box between front seats;just pull the back cover.
    I used no relay to activate the sub (direct from acc).
    Result is perfect.
    just be carefull to leave clear the air flow for rear passenger. 8)
  3. ifogel
    ifogel New Member
    32
    New York, NY
    Thanks...
    How much did it improve the sound? Did you add anything elese like a n amp or new speakers?
  4. frenchie
    frenchie Member
    150
    48
    The quality of the bass is now really good; all the loudspeakers were changed. the power of original radio_amp is enough.
    When you change the loudspeakers, you should stick inside the doors some damping material to avoid the "drumming/rattling "of the doors.
    At the same time it will change the sound when closing the doors , you will now have a luxurious car.. :mrgreen:
  5. aolm
    aolm Junior Member
    82
    New Jersey
    Any pix... I assume I would get power for my baselink from the battery in the back.... like my old gen II. Where did you tap in for speaker in. (non jbl)
