Where is bluetooth playing getting the artwork?
Discussion in 'Gen 4 Prius Audio and Electronics' started by nategold, Jul 12, 2016.
  1. nategold
    nategold Member
    117
    38
    Arlington, MA
    Sometimes it shows the right artist and sometimes totally weird. It is not coming from the iPhone 6S, unless you connect that via USB and play from that - then the artwork is really the album artwork.
    Clearly it is getting some kind of data via the internet. Is that using my cell data? Or does it come via the radio?
  2. Gen 2 Tom
    Gen 2 Tom Active Member
    333
    286
    Lincoln Park NJ
    I've seen art work from XM radio stations. Sometimes they send a generic picture of someone singing, but other times the album art work. I think FM and AM have only text information that's been around for years. But maybe the HD radio, which we have, can receive data, don't know.
    49,371
    even my usb shows funky art sometimes.
  4. frankdogg
    frankdogg Junior Member
    Gracenote
    wrprice and kithmo like this.
  5. lcastro
    lcastro Junior Member
    Mexico City, MX
    It's a database pre-loaded into the head unit. This database is called "Gracenote". Their web site is Gracenote | A Nielsen Company if you wan't to know a little more about it.
    kithmo and RCO like this.
  6. nategold
    nategold Member
    117
    38
    Arlington, MA
    My iPhone 6S always shows the same artwork as on the phone when connected via USB. Bluetooth - hit and miss.
  7. liquidtenmillion
    liquidtenmillion Active Member
    261
    194
    Easley, SC
    There are a few sources for the pictures depending on what exactly you are listening too. This is definitively how the car chooses which picture to display.
    HD radio(FM): can send picture from station, if not then it looks at internal grace note DB
    Regular FM: always looks at grace note db
    XM: Always sends artist picture, never looks at grace note DB
    bluetooth: always looks at grace note DB, never gets from device
    ipod/usb: gets from device, if no picture properly embedded in file metadata gets from grace note
    CD: gets from CD if embedded in cd, otherwise grace note
    Pandora/iheartradio/other entune audio: always gets from entune audio source app
    It's easiest to look at grace note as the "backup method". If the source doesn't send it's own picture, it then looks at gracenote. Also grace note first looks for a matching Album, if it doesn't have that album artwork in it's database it falls back to Artist. It it doesn't have a matching artist it falls back to Generic Genre. If it doesn't have an image for your genre or a similar detected genre, you get a generic blank image.
    Grace note is updatable, but astoundingly it is included in the ultra expensive navigation map updates. You cannot update grace note without updating maps, and vice versa. It is actually supplied as the same file! The gracenote/map update. Most dealerships aren't even aware that the map update contains the grace note update. Most other vehicle manufacturers provide free grace note updates that can be loaded over USB.
    Just like the maps, they are already 2 years out of date when released brand new.
    #7 liquidtenmillion, Aug 2, 2017
    tomcornell, lcastro and 2k1Toaster like this.
  8. ChapmanF
    15,435
    I have a Gen 3, so maybe it changed for Gen 4, but in Gen 3, the Gracenote update is described in T-SB-0108-15. The database is on the same USB stick at the dealer as the map update, but: "A Navigation Map Update is not required to complete the Gracenote® update."
    The Gracenote update has to happen first, but they can stop there if you don't want the map update. There'd still be some charge for shop time, but only the map update involves a license purchase.
    -Chap
    RCO likes this.
  9. Theone23
    Theone23 New Member
    Denver, CO
    When playing from my bluetooth, only seeing artwork when I'm in park. Is there a way to change this in the 2020 Prius?
