Where is evap vent valve and how hard is it to replace
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by John trapp, Jun 13, 2018.
  1. John trapp
    John trapp Junior Member
    Hyannis
    Where is evap vent valve and how hard to replace
    51,155
    welcome!
    log in to toyota tech info, and search for the valve location a nd replacement procedure.
    all the best!(y)
  3. Paul Schenck
    Paul Schenck Active Member
    523
    306
    Fresno, California
    It’s on top, at the right(passenger side) front corner of the fuel tank. You have to drop the fuel tank to get to it there is a plug, two bolts and hose fitting that is easier to disconnect in back by the charcoal canister.
    It took me 6 Hours and I needed an assistant to help me lift the tank back up. Hint do this when the tank is near empty as it is not so heavy.
    iPhone ?
