Where is Maintenance Requirement Warning?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by FireFire, May 2, 2015.
  1. FireFire
    FireFire Junior Member
    95
    Ontario, Canada
    My C is due to the maintenance requirement by the mileage. But there is no warning light at the dash board. Should I go ahead to do the oil change or just wait until the light comes up?
    I heard other brand name does have oil life sensor which tells you when the oil goes bad. Does Toyota finally catch up?
    Thanks
  2. Mendel Leisk
    38,729
    If you're in Canada there isn't one, I think. The hatchback doesn't have it. Show your location.
    49,500
    toyota does finally catch up, we just don't know when. how many miles on her?
  4. FireFire
    95
    Ontario, Canada
    Yes. I am in Canada. So there is no indication for maintenance?
    The last stick on the windshield is 40200 and my C is ready 41xxx.
    Just changed this afternoon. Let's see how it goes.
  5. FireFire
    95
    Ontario, Canada
    Just off the phone with Toyota Canada. There is no indicate at all for Prius C Canadian version and will no update to support that.
    Feel bad about that, how diff just at add a counter in the software. :( High tech vehicle with no such kind of small feature....
  6. bisco
    49,500
  7. Mendel Leisk
    38,729
    Well, you do have odometer. And nothing to reset, count your blessings. ;)
