where is the battery
Discussion in 'Prius v Main Forum' started by john williams, Jun 3, 2017.
  1. john williams
    john williams Junior Member
    where is the 12v battery located exactly? and is it a sealed type or does it need water? dealer always does service so i never knew
    49,371
    not sure on the v, the lift back has it in the right rear corner of the hatch, and it is under the rear seat in the c. they are all sealed, with a vent tube running any gases outside.
    your o/m should show the location, as well as the location under the hood where you can jump start it.
    edit: apologies, i see you have a lift back,so ignore my v comment, that was based on the forum i saw that you posted in.
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    As you look in the back, under the floor in a panel to the right side.
  4. rjparker
    rjparker Tu Humilde Sirviente
    7,917
    4,678
    Texas Hill Country
    Normally does not need water
  5. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    AGM type. No watering to worry about, although there were strange instructions on charging rates and length when I read about it....
