Where is the charging cable?
Discussion in 'Prime Main Forum (2017-2022)' started by hakan, Jul 3, 2020.
  1. hakan
    hakan Junior Member
    San Francisco
    2020 Prius Prime
    Just got a 2020 Prius Prime a couple days ago. I forgot to ask about or check the charging cable. I wanted to try charging it and can't find it. I looked in the compartments under the trunk but it wasn't there. Are there any other places it can be?
  2. Tideland Prius
    16,615
    Usually they just place it in the trunk along with the carpet mats so that everything is visible to the owner.
    It should be in a plastic bag and it has a blue handle with black cabling and a black power brick.
  3. schja01
    schja01 Senior Member
    1,844
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    There are several trunk compartments. Check the one closest to the rear bumper which is designed to store the cable when not in use. It’s wide and thin and runs nearly the width of the trunk.
    Tideland Prius likes this.
