Where is the "disable button"?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by brin wood, Oct 20, 2013.
  1. brin wood
    brin wood Member
    100
    upstate NY
    I read that if you have to park your Prius for an extended length of time, you should press the disable button to avoid the batteries going flat.
    Where is this button?? Sounds like a great thing.
  2. Tickwood
    Tickwood Active Member
    334
    101
    San Diego
    2020 Prius Prime
    Some (not all) Gen II cars have a small button under the steering wheel that turns off the SKS (smart key system). That reduces battery drain to some extent.
