Where is the fuel pump relay for the 3rd gen Prius? (for anti-theft kill switch)
Discussion in 'Gen 3 Prius Technical Discussion' started by Sam Darcy, May 13, 2023.
Tags:
  1. Sam Darcy
    Sam Darcy New Member
    PA
    Hi! I'm trying to install an anti-theft kill switch by adding a switch to the wire that connects to the fuel pump relay, a procedure I have done before on my older '04 Honda Civic. (With the kill switch off, the car won't start as the fuel pump won't work)
    1. Does this procedure still work for a hybrid car like the 3rd gen Prius?
    2. I can't seem to find the fuel pump relay in a 3rd gen Prius online. Which relay/fuse do I use to create such a kill switch?
    3. What other theft prevention DIYs do you suggest? :)
    Thanks! Sam D.
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,918
    4,680
    Texas Hill Country
    There will be enough ev power to drive it on a trailer.
    IMG_2053.jpeg The catalytic converter is what they want. They will leave the rest of the car.
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,154
    2,204
    Taylors, SC
    StarCaller likes this.
  4. Michael Kent Handy
    Michael Kent Handy Junior Member
    58
    Fort Worth, Texas
    I'm trying to determine my 2011 prius fuel pump relay(if there is a specific one) I have a no start problem for my engine. I thought replacing the fuel pump module would fix this, but so far has not. I've studied the fuse box diagrams, related them to my under hood fuse box lid diagram, and do not see a specific relay dedicated to the fuel pump. My only clue is maybe the one labeled IGCT, but this is only my opinion based on description of how that is related to power management control
  5. rjparker
    7,918
    4,680
    Texas Hill Country
    2nd try in the same thread is the charm?
    Fuel Pump
  6. ChapmanF
    15,470
    The alert reader will notice that both of the relays shown in that diagram are within the same gray-shaded thing as the EFI MAIN fuse. That'd be the four-fuse-slot integration-relay thing toward the outboard side of the underhood fusebox. 1B is the middle one of the three connectors plugging into the bottom of it.
  7. rjparker
    7,918
    4,680
    Texas Hill Country
    Part 82641-71010
    Brian1954 and douglasjre like this.
  8. douglasjre
    douglasjre Senior Member
    1,858
    647
    Orlando, FL
    Cars can be stolen w flatbeds and tow trucks. They go straight to the port then overseas. Foreign countries don't give a F
    I think they want luxury and high end cars, not pri
  9. Michael Kent Handy
    58
    Fort Worth, Texas
    Thanks Chapman! I also was able to get a confirmation on the same from a Toyota parts supplier that had an "ask a question" option. I really appreciate your technical knowledge evident in the details you provide!
  10. Michael Kent Handy
    58
    Fort Worth, Texas
    Thanks...I did not realize thats a relay cassette. Guess I'll have to pull it to take a closer look.
