Where is the gen 3 Prius door switch wire (to tap-in factory alarm)
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Jenny2010Prius, May 14, 2022.
  1. Jenny2010Prius
    Jenny2010Prius Junior Member
    37
    Calgary
    2024 Prius Prime
    SE
    I just couldn’t find the Gen 3 (2010) Prius door switch wire under the driver side step sill.
    Considering rampant Catalytic Converter theft these days, I decided to install a DIY tilt alarm with mercury gravity switches. The plan is simple, just tap in the door switch wire in the existing factory alarm system. The diagram shows it clearly.
    Loosed door switch, and confirmed the wire is a thin brown one.
    Opened up the step sill and found dozens of wires. There are 2 brown wires. Stripped them one by one and did tests. None is the door switch wire, as one of the brown wirings is always ground no matter if the door is closed or not, the other one never connected to ground.
    Does anyone have any ideas or advice?
  2. ChapmanF
    18,248
  3. tony_2018
    tony_2018 Member
    227
    68
    There are dedicated sites that can help, one is 'the12volt'. You can also google search 'alarm wiring' for your specific car but you'll still need a dmm to test/verify wires.
  4. rjparker
    rjparker Tu Humilde Sirviente
    10,164
    6,319
    Texas Hill Country
    LR1 probably pin 54
