Where is the Gen 4 discussion?
Discussion in 'Gen 4 Prius Main Forum' started by sorka, Sep 18, 2019.
  1. sorka
    sorka Active Member
    1,004
    196
    Merced, CA
    2019 Prius
    I feel lonely in my new 2019 Limited compared to the crazy party it was in the gen 2 forum when I bought my 2009.
    mark27lim likes this.
  2. TNeil
    TNeil Junior Member
    I
    anyone think it’s possible to do a Prius prime tail light conversion on gen 4 to non prime without too much work to body?
    I just love the Prime rear end..
    49,371
    less owners than back then?
    Montgomery likes this.
  4. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    @krmcg has done many mods to the first Gen 4 seen here.
    There are others too.
    krmcg likes this.
  5. krmcg
    2,592
    2,390
    Whittier, CA
    LOTS of mods. Multiple Suspension adds. Folding side mirrors. Raised cargo area. BeatSonic Apple mirroring. Purchased fogs - getting installed soon.
    Mambo Dave, Montgomery and bisco like this.
  6. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    No - it's too different. Check the profile of the back and the hatch. Unless you've got unlimited $$$.
    Prodigyplace likes this.
  7. alanclarkeau
    7,044
    7,584
    There was a massive discussion on Gen 4 from about 6 months before it arrived and ongoing for a year or 2. Pretty well everything was said back then - we're all waiting for the Gen 5 which will start the excitement again.
  8. sorka
    sorka Active Member
    1,004
    196
    Merced, CA
    2019 Prius
    Speaking of light conversions, irritated that the top trim level Limited on the 2019 in the US doesn't have the fogs or accent lights. Every other country on the planet gets them but the extra tiny bit of electricity pushes the Limited with the 17" wheels just under the EPA rating for all the other trim levels without the 17" wheels.
    So I've spent $850 on factory parts to do the entire conversion. I might have to spend another $150 on the steering column stalk controls to get the fog switch if the fogs aren't already on by default when the low beams are on.
  9. alanclarkeau
    7,044
    7,584
    The TOYOTA fog lights are useless anyway.
    A proper FOG beam needs to be like this:
    But PRIUS "fog" lights spray light everywhere and are worse than useless in fog - a flood beam:
    And when there isn't fog, some drivers put them on just to annoy other drivers, but being unfocussed down, they just emit glare..
    ice9, Mambo Dave and Prodigyplace like this.
  10. liquidtenmillion
    liquidtenmillion Active Member
    261
    194
    Easley, SC
    The foglights in my 2017 seem to be aimed very low, the beam doesn't go any further than 2 or 3 feet. I personally find them useful, at least in the fact that since they are lower they make it easier for others to spot my car in fog.
    sorka and krmcg like this.
  11. Mendel Leisk
    38,644
    On my third gen, I can barely discern a difference when I turn them on and off. Typically I'll do that a few times, back and forth, then leave them off, get back to driving.
    alanclarkeau and Mambo Dave like this.
  12. sorka
    sorka Active Member
    1,004
    196
    Merced, CA
    2019 Prius
    And they should be yellow since that penetrates fog far better than 4000K does.
  13. Prodigyplace
    11,696
    11,318
    Central Virginia
    The current LEDs are likely 6000K.
    alanclarkeau and sorka like this.
  14. mistermojorizin
    mistermojorizin Active Member
    310
    136
    usa
    2019 Prius Prime
    "TOM: So the question becomes, to yellow or not to yellow? There's a lot of debate about this, but the research says that yellow lights are no better than white lights at penetrating fog. The theory bandied about was that yellow light has a longer wavelength and is therefore less likely to be reflected by the fog particles. Turns out, this is complete poppycock.
    RAY: Apparently, the fog particles themselves are so big that they reflect all colors of light. Basically, all light bounces off of them, so using yellow light instead of white light gives you no advantage."
    Blog Post | Do fog lights work? | Car Talk
    krmcg likes this.
  15. ice9
    ice9 Active Member
    581
    343
    norfolk va
    2018 Prius
    Welcome to the club. We were told that our mama wears army boots and our cars were ugly, so we clammed up and stopped talking to people. :censored:
    krmcg and Prodigyplace like this.
  16. Prodigyplace
    11,696
    11,318
    Central Virginia
    That is true for many people today. ;)
    ice9 likes this.
  17. RRxing
    RRxing Senior Member
    2,519
    1,790
    NEPA
    My wife said it looked like a set of lips.
    Lightning Racer likes this.
  18. sorka
    sorka Active Member
    1,004
    196
    Merced, CA
    2019 Prius
    Note, to mod, can you please retitle my thread to reflect what thread is actually about :p
    Prodigyplace and ice9 like this.
  19. alanclarkeau
    7,044
    7,584
    I read that yellow was good as it alerts other drivers that it's a car - not another light, as not many lights are yellow. But it's probably 40 years since I've seen yellow fogs.
    My 1973 VOLVO had white fogs, but they were a narrow flat beam and worked well in fog, and were wired properly so they only worked if the headlights were off. Putting headlights on with them, just defeats the fog and blinds you again - which is how most manufacturers do it nowadays - because they're only expensive decorations.
  20. sorka
    sorka Active Member
    1,004
    196
    Merced, CA
    2019 Prius
    All I know is that yellow produces a lot less glare through fog than blue does. It's especially true for me given that I have mild cataracts and blue lights scatters causing lots of haze while yellow light doesn't.
    alanclarkeau likes this.
