Where is the horn relay?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by prius4ed, Feb 20, 2011.
  1. prius4ed
    prius4ed Member
    120
    Irvine, CA
    My horns aren't working. I'm getting power at the horn fuse, but no power at the horn connectors. Where is the horn relay located? Is it in the fusebox under the hood? There are many relays, but none of them labeled "horn".
  2. vertex
    vertex Active Member
    670
    143
    new york
    2018 Prius Prime
    If I understand the manual correctly, it is not very clear, it is in the rectangular box screwed to the cowl in the engine comparment near the middle of the compartment.
  3. Patrick Wong
    18,200
    6,471
    The HORN relay is located within a four-relay module installed within the main relay/fuse box next to the inverter. That module is labeled Unit C.
    However, I agree with northwichita's post in this forum, which states that since you have electrical problems with the horns and the airbags, it seems likely that the spiral cable within the steering wheel hub is the problem.
  4. prius4ed
    prius4ed Member
    120
    Irvine, CA
    Thanks!! You definitely have a great suggestion (I am very impressed that you put together info from my separate posts about the airbag light and the horn)! I will pull the steering wheel (battery disconnected, of course) using care not to deploy the airbag and check the connections. I had installed a clockspring and airbag when the original airbag blew. The "clockspring" has at least 2 conductors -- to power the airbag. How does the single horn button contact get connected through the clockspring -- a third clockspring, I guess? I should also note I can't say the horn stopped working at the same time the airbag light appeared, as I rarely use the horn and haven't tested it since I repaired the car's front end.
  5. prius4ed
    prius4ed Member
    120
    Irvine, CA
    Another comment -- the horn fuse is on the "C" integrated relay block, so can I assume the relay is under that fuse, in the "C" block? I pried the "C" block out, and took a look in there. I'm guessing the relay can't be individually replaced. I can test the relay function but I think you may be right; I'd be better off checking the steering wheel first. Or, I may check for a horn button response at the relay coil neg terminal. I have a color coded wiring diagram. Those integrated relay blocks (82641-47020) cost $134 new!! Ouch!
  6. Patrick Wong
    18,200
    6,471
    Hi Ed,
    You are right. I took a look at my 2004 and relay block C is the one containing the horn relay. The 2004 Toyota electrical wiring diagram does not label the two relay blocks, while the 2006 version confuses B and C.
    If you are going to pry out the relay block to gain access to the terminals, then you can also insert a jump between the switched terminals to confirm that the wiring to the horns, and the horns themselves, are good. Then, you can use an ohmmeter to see whether the relay terminal that connects to the horn switch shows continuity to ground, when you have a helper depress the horn switch. If those two tests are good then the relay is bad.
    ydpplqbd likes this.
  7. kenvandellen
    kenvandellen GPKen
    Grosse Pointe Park, MI
    Four Touring
    I thought I'd horn in, and mention that my 2004 Prius (269K miles and going strong) has only one horn now. When new, it had a weak two-tone honk; now it's a weaker one-tone peep. I thought it might be merely that a wire is off one horn, but didn't know where to look. I assume that both horns have the same fuse and relay.
  8. QuiGonJohn
    QuiGonJohn Junior Member
    79
    Davie, FL
    Ken, the same thing happened to me on my 2009 Prius. Then even the weaker, higher-pitched one tone stopped working. When that happened I finally started checking things out. The fuse was good, 10A, I swapped it with the hazard lights and they still worked with the horns fuse. Next I looked around under the front of the hood. I found the horns and lo and behold, on both, the wire had somehow come loose from the connector it was attached to, which then plugs into the horn. In other words, the connectors were still as they should be, but the wires were out of the connector. Both of these must have happened while I was using the horn, so someone didn't do this. In fact, in each instance one of the horns had stopped working, I had been using them.
    Anyway, I was able to remove the horns, disassemble the connectors. Then solder a longer length of wire onto the wires under the hood, (so I had some length to work with). I then was able to connect and solder the other end of those wires onto the connector. I put heat shrink over both joints (where the original wire and my pigtails meet), as well as over the end where I connected my pigtails to the connector plug. Then I plugged in the connectors and remounted the horns and now they both work.
    I came here to Prius Chat to do a search and see if a lot of other people have had a similar problem.
    homiejoe2 likes this.
  9. andrew kb
    andrew kb New Member
    Louisville, KY
    QuiGonJohn wrote: I was able to remove the horns, disassemble the connectors. Then solder a longer length of wire onto the wires under the hood, (so I had some length to work with). I then was able to connect and solder the other end of those wires onto the connector. I put heat shrink over both joints (where the original wire and my pigtails meet), as well as over the end where I connected my pigtails to the connector plug. Then I plugged in the connectors and remounted the horns and now they both work. I came here to Prius Chat to do a search and see if a lot of other people have had a similar problem.​
    John, thanks for the answer. This helped me find a small black wire that was broken off from the connector to the middle horn of my 2007 Prius. There doesn't appear to be any wire sticking out of the connector. I've never attempted anything like this, so wonder if you can explain the procedure? I assume I must take the metal piece off so I can get at the horn, then attach a new length on and solder that to the connector...?
    1) Is it obvious how to disassemble the connector? I assume you need to do that in order to solder the wire onto it? Is there a wire in the connector where you can pigtail your additional wire length?
    2) What kind of wire and is that something I can get at Home Depot? Also, any recommendation for soldering tool?
    3) Are you just twisting the wire together where you are adding the extra length, and then just solder in the connector?
    4) I assume I can get heat shrink at a hardware store. Can you heat it with a hot glue gun or do you need a special tool?
    Thanks much!!
    andrew​
  10. e7an
    e7an Junior Member
    minnesota
    Three Touring
    I have a 2008 Prius and I am having problems finding the horn relay...and I've looked at the infamous Block C...and it does have the horn fuse (which is in tact)...but it does not contain any Relay. Anybody able to give me a definitive answer on it's location? I know it exists...they sell one for the car. I'll make a nice youtube video to show the world where it is if I ever find it. Thanks. -e
  11. Patrick Wong
    18,200
    6,471
    Block C contains four relays in the one unit.
  12. Fraprius
    Fraprius New Member
    Roma
    Have You Cod reley Horn per Prius 2011?
  13. CARSFAN4
    CARSFAN4 Junior Member
    Los Angeles
    2015 Prius c
    Hi Patrick, can you explain to me how to pull out (pry) the relay cover so I can have access to the switch terminals. I need to hookup directly a temporary horn switch button until I will fix the steering wheel spiral. Thanks
  14. CARSFAN4
    Los Angeles
    2015 Prius c
    Ok,Patrick, my car is a Prius C. I succeeded to pull out the relays cover but instead of hooking up the new horn switch to the relay can I just connect it directly to the red battery contact which is in the black triangular box with relays near the hybrid inverter on the right side of the engine compartment?
  15. CARSFAN4
    Los Angeles
    2015 Prius c
    Hey Patrick, I succeeded to pull out the black plastic cover signed w.C. My question is: instead of connecting the temporary horn switch to the horn relay, can I connect it directly to the red battery cap located in the black triangular fuse box near the hybrid inverter? This fuse box has a metal connector coming from the battery positive pole. This connector is used for emergency engine start up when pulling cables from another car battery. 20190620_212317.jpg 20190620_212352.jpg 20190620_212317.jpg 20190620_212352.jpg
  16. Patrick Wong
    18,200
    6,471
    You could connect the horn switch to the dedicated positive jumpstart terminal. However you also need to include an inline fuse of the appropriate current rating. 5A probably is sufficient for the horn.
  17. John CSV
    John CSV New Member
    Vancouver WA
    Hi there, new to the forum and new used proud Prius owner of a 2012 V
    I have been trying to figure out why my horn doesn't work after 5 months of having this car just found out the horn does not work,
    after reading these forums for the last few weeks and going over everything I am still stuck, I am pretty sure its the unit C relay but for the life of me I have no idea how to get the cover off or how to take the unit out to buy a replacement.
    Could you please please share with the forum how to pull out the relay and the cover and even where the fuse for the horn is.
    Thank you
